on 05-03-2022 15:56
Recent upgrade to M350. Upload now faster (36Mbps) but download capped to previous speed under M100 (90Mbps). This is after resetting the modem (hub 3) and connecting by ethernet cable.
on 23-11-2022 21:01
@Client62 wrote:right is PC connected via 2.4Ghz WiFi just to show what happens where speed is lost after the Hub3 on M125 service.
use 5GHz or get a better wifi router
on 23-11-2022 22:09
My preference is to disable WiFi & use a 1Gb/s network cable.
on 23-11-2022 22:30
I found a link to run Realspeed but the error message said "The is not available on this network" (or words to the same effect).
Mike
on 24-11-2022 08:37
How odd.
The real speed link : https://www.samknows.com/realspeed/ worked just now from the PC's Edge + Firefox browsers & from Chrome on an Android mobile.
I've seen the occasional error relating to not finding the HUB, a retry normally soon clears that.
The expectation is that the test is run via a device connected to the internet Virgin Media Hub in our case it works directly connected or via of our 2x WiFi access points.
We are using the Hub3 in Router mode, I have not tried with the Hub in Modem mode.
