on 14-08-2022 11:32
Just wanted to see if someone from VM can check my connection. The online test your kit doesn't seem to be working at the moment
I've noticed a dip in my speeds plus my broadband quality monitor has horrendous ping suddenly
on 14-08-2022 14:53
14-08-2022 17:28 - edited 14-08-2022 17:33
Hub 3 in modem only mode - router being an Amplifi HD. Nothing has changed on the setup since this introduction into the red spikes in ping.
Just the usual devices connected via ethernet: CCTV, Alarm etc.
Edit; managed to do a test on my line via the online status checker. Although initially shows as no issue with my service, after doing the test it states there is an issue but with no indication if/when it will be rectified
on 14-08-2022 18:49
Hi @RandomR
Try the automated Service Status number on 0800 561 0061. This often gives details of more local issues (if known) down to postcode level along with estimated fix date and time.
on 14-08-2022 19:28
on 14-08-2022 23:19
on 15-08-2022 10:03
Just called up VM. Apparently a damaged cable causing the issue. Started last week Tuesday and still the ETA for the fix is tomorrow 9am approx...
Not a good sign. I'm guessing VM don't provide compensation for degraded quality as opposed to pure lack of service?
on 15-08-2022 14:04
on 17-08-2022 14:37
Good Afternoon @RandomR, thanks for your post on our Community Forums, and I'm sorry to hear of the recent issues in the local area.
I've been able to look into this for you, and it appears that the fault is still present and is effecting approximately 25% of the customers in the local area.
Our team is on the case and are doing all they can to ensure this is fixed as soon as possible.
Kindest regards,
David_Bn
on 17-08-2022 14:56
Hi there,
The issue was resolved yesterday for a limited period of time it seems. My packet loss disappeared. But the issue seems to have returned today again.
Super annoying on zoom calls.
What's the ETA fix, as it's nearly approaching a week of this issue being present.
