carterst
  • 7
Splitter causing speed issues?
Since engineer install of my M500 service (now migrated to M600) back in March I've been getting my advertised upload speed but in most cases struggled to get above 220mbps download speed via direct ethernet connection to the hub 3. Wifi speeds are adequate at this time as most of my equipment is ethernet.
This falls short of the minimum speed guarantee. I've reached out to VM but while I'm waiting a response I wondered if the splitter that was installed (I have the TV service too) could be causing an issue?
Does the splitter cause degradation in download speeds?
Tags (2)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Splitter causing speed issues?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Can you please
carterst
  • 7
carterst
  • 7
1402750000-138256 qam30
22027500003.240256 qam9
32107500002.940256 qam10
42187500002.540256 qam11
52267500002.238256 qam12
6234750000240256 qam13
72427500001.740256 qam14
82507500001.740256 qam15
92587500001.540256 qam16
102667500001.540256 qam17
112747500001.240256 qam18
122827500000.538256 qam19
132907500000.238256 qam20
14298750000038256 qam21
15306750000-0.540256 qam22
16314750000-0.438256 qam23
17322750000-0.238256 qam24
18330750000-0.538256 qam25
19370750000-0.538256 qam26
20378750000-0.938256 qam27
21386750000-138256 qam28
22394750000-138256 qam29
23410750000-138256 qam31
24418750000-1.438256 qam32
1Locked38.9610
2Locked40.3520
3Locked40.3620
4Locked40.3580
5Locked38.9780
6Locked40.3910
7Locked40.3800
8Locked40.3800
9Locked40.3490
10Locked40.3500
11Locked40.3500
12Locked38.9650
13Locked38.6650
14Locked38.9580
15Locked40.3930
16Locked38.6780
17Locked38.6990
18Locked38.9630
19Locked38.9610
20Locked38.91120
21Locked38.91000
22Locked38.9770
23Locked38.9670
24Locked38.6890
13940000048512064 qam2
22580000046512064 qam4
33260000046.5512064 qam3
44620000048512064 qam1
1ATDMA0010
2ATDMA0060
3ATDMA0030
4ATDMA0070
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
54k;fg87dsfd;kfoA,.iyewrk
SFID954
Max Traffic Rate690000278
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID953
Max Traffic Rate44000278
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Your Downstream Power Levels individually are all within spec but, the differential between the lowest at -1.4dBmV and the highest at +3.2dBmv is too great.
This will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
