bcne12563
  • 20
Message 1 of 14
Speed
I'm paying for 350mb and lucky to get 15mb at most times. Keeps dropping off too. Tried all the solve its and still no good
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 14
Re: Speed
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
bcne12563
  • 20
Message 3 of 14
Re: Speed
https://www.thinkbroadband.com/broadband/monitoring/quality/share/130cebdf54c35ad57071051fb51c75ee74f7501f
bcne12563
  • 20
Message 4 of 14
Re: Speed
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
14190000005.140256 qam30
2187000000840256 qam7
31950000007.640256 qam8
42030000007.340256 qam9
52110000007.140256 qam10
62190000006.540256 qam11
72270000006.440256 qam12
8235000000640256 qam13
92430000006.540256 qam14
102510000006.540256 qam15
112590000006.840256 qam16
122670000006.640256 qam17
132750000006.640256 qam18
142830000006.540256 qam19
152910000006.540256 qam20
162990000006.640256 qam21
173070000006.940256 qam22
183150000006.640256 qam23
193230000006.440256 qam24
203790000005.940256 qam25
213870000005.940256 qam26
223950000005.840256 qam27
234030000005.540256 qam28
244110000005.540256 qam29
1Locked40.356160
2Locked40.34617522
3Locked40.34288308
4Locked40.36727505
5Locked40.31772331
6Locked40.32811242
7Locked40.32203183
8Locked40.91951149
9Locked40.31371119
10Locked40.3993102
11Locked40.376381
12Locked40.3723110
13Locked40.3706137
14Locked40.3731179
15Locked40.9705213
16Locked40.3693215
17Locked40.3690218
18Locked40.9659257
19Locked40.3721278
20Locked40.364895
21Locked40.366590
22Locked40.364590
23Locked40.364699
24Locked40.362244
bcne12563
  • 20
Message 5 of 14
Re: Speed
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
16029999138.8512064 qam1
23940000936.8512064 qam4
34620001237.3512064 qam3
45369998638.8512064 qam2
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
bcne12563
  • 20
Message 6 of 14
Re: Speed
Network LogTime Priority Description
03/10/2020 15:59:39noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2020 15:52:56Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/10/2020 18:53:50noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/10/2020 18:53:50ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/10/2020 08:53:12noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/09/2020 07:19:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/09/2020 07:16:1noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/09/2020 03:32:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/09/2020 23:35:48noticeSW download Successful - Via NMS
29/09/2020 23:34:16noticeSW Download INIT - Via NMS
28/09/2020 01:02:49noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/09/2020 01:02:49ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/09/2020 00:32:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/09/2020 00:32:9criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/09/2020 00:32:0criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/09/2020 00:30:24criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/09/2020 00:30:14criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/09/2020 00:28:37Warning!B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/09/2020 00:27:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/09/2020 00:26:38criticalDHCP FAILED - Request sent, No response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 14
Re: Speed
How are you connecting your device[s], Wi-Fi or ethernet cable ?
bcne12563
  • 20
Message 8 of 14
Re: Speed
Devices are connected by wifi
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 14
Re: Speed
What speed do you get using a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
bcne12563
  • 20
Message 10 of 14
Re: Speed
Download 184
Upload 36
