on 03-12-2021 13:47
I recently got the Voly upgrades. After a test I was told my existing hub wasn't up to it and I'd get a replacement. Hub4 arrived yesterday. I changed over the hubs, the Hub4 did an update and rebooted. Everything connected to the network came back online. So far, so good.
I did a speedtest to show off my shiny new Gigabit download speeds.
What an utter let down 😞
On the old hub I had 500Mpbs and generally got 400 - 450. With the Hub4 I'm 200Mbps. If I'm lucky.
These speeds are the same whether it's something on the network or directly to the hub.
Any ideas?
Cheers
Steve
Answered! Go to Answer
on 03-12-2021 21:52
Are you testing on wired or wireless devices?
What does the below site show?
https://samknows.com/realspeed/
on 05-12-2021 10:59
Hi All,
Worse still this morning 😞
First off the thinkbroadband graph from yesterday (Sat 04/12)
https://www.thinkbroadband.com/broadband/monitoring/quality/share/56323ff430a17dcedec09e9cf21412294b...
These are from samknows
on 05-12-2021 11:02
The 2 images from samknows are the BEST of tests with 3 different devices connected directly to the hub and with nothing else connected to the hub.
I've tried the tests with the NIC set to 'Auto negotiate' and forced to 1GPBS, Full Duplex.
I've done a factory rest on the hub and it's had several reboots.
Cheers
Steve
05-12-2021 11:11 - edited 05-12-2021 11:12
@stedav99 wrote:The 2 images from samknows are the BEST of tests with 3 different devices connected directly to the hub and with nothing else connected to the hub.
Cheers
Steve
Please try the below:
A second speed test will run.
What speed do you get?
on 05-12-2021 11:32
82Mbps down, 22 up
on 05-12-2021 11:42
@stedav99 wrote:82Mbps down, 22 up
And this is wired?
Can you access your HUB. There should be a 'Connected Devices' section. Can you check what the connected speed shows for the device you are using?
on 05-12-2021 12:07
Yep, this is wired. last few tests have been with Virgin supplied CAT6 but I've tried with other cables, makes no difference.
05-12-2021 12:19 - edited 05-12-2021 12:28
@stedav99 wrote:Yep, this is wired. last few tests have been with Virgin supplied CAT6 but I've tried with other cables, makes no difference.
Yes, very strange considering it appears you are getting full speed to the HUB!
Could you try a full reset, which means holding in the reset pin for at least 30 seconds (Wasn't sure if you would have done it previously for a full 30 seconds)?
Please keep in mind this will reset any changes you'd made to the HUB settings.
on 05-12-2021 13:10
Reset via button on rear, no real difference 😞
on 05-12-2021 13:11
@stedav99 wrote:Reset via button on rear, no real difference 😞
I can only suggest the HUB is faulty.
