on 26-06-2021 18:30
I use Macbook Pro with no ethernet port but wifi works very well, was getting D/L speeds up to 200 mbs or more, for past several weeks its dropped to between 50-90 mbs- have only added one more device ( Ring video bell).
I checked with ethernet cable on a Hp laptop, similar speeds.
Only thing I noticed it was some lag with Netflix and Amazon on TV, no issues with d/l large files or streaming.
I do have multiple devices connected( 12) and some may be using 2.4 GHz but not sure.
I do not fully understand Router stats but here they are- downstream ones.
I have ethernet cables connected to apple tv, Sky box for TV and HIVE, all else is on WiFi.
My WiFi is set to auto for channels.
Any advice to improve speed will be highly appreciated. Thanks
These stats were taken when no other device was actively used D/L speeds on samknows were 85 with a ping of 18s
Answered! Go to Answer
on 29-06-2021 18:31
on 29-06-2021 18:37
My pleasure.
Enjoy your evening!
on 01-07-2021 22:35
Miraculously my speeds are up to normal tonight:)
on 02-07-2021 10:23
Hi DocMi
That's good to see
Can you please keep an eye on this and if it drops
Pop back on here and let us know
Gareth_L
on 02-07-2021 10:41
Thanks Gareth, will do.
This forum has been very helpful.
on 06-07-2021 19:37
Network issues are back , low speed and now the hub keeps rebooting on its own. I fixed an Engr appointment for today which was changed to Friday - now I get a message saying that Network problems are being investigated in my area hence vidd see it is on hold !! Broadband is running at lower speeds for now. Thanks for looking into this
on 06-07-2021 21:26
My speed is still slow , < 80 mbs, Engr appointment looks to be on hold; text sent to me said that network check has been completed.
Speed has still not improved so please help re-instate engr appointment
on 07-07-2021 12:00
Thanks for your reply, DocMi,
I have set up an engineer’s visit for you which you will be able to view from your online account here.
Cheers,
Corey C
on 07-07-2021 13:44
Got it , thanks very much Corey
on 07-07-2021 14:43
You're welcome, DocMi.
