Mancjames
Message 1 of 8
Speed keeps going down
Hey,
Sorry know there are a few of these! I've joined virgin a few days ago and for some reason our internet just keeps slowing down. I've restarted/reset the router and it fixes it for a bit but then it just goes to a really slow speed again.
I've attached a copy of the downstream, upstream and network log below as read somewhere that was the best thing to do but I'm not great at this sort of thing so honestly any advice would be great!
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
1226750000440256 qam12
21787500005.440256 qam6
31867500005.440256 qam7
41947500004.940256 qam8
52027500004.640256 qam9
62107500004.540256 qam10
72187500004.340256 qam11
82347500003.940256 qam13
92427500003.740256 qam14
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1394000044512064 qam10
2258000613.9512064 qam12
3326000093.95512064 qam11
4461999983.95512064 qam9
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
Network LogTime Priority Description
22/03/2019 11:53:54criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/03/2019 18:15:3Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 2.35K
  • 112
  • 304
jpeg1
Problem sorter
Message 2 of 8
Re: Speed keeps going down
Those figures are absolutely fine.
What speeds are you measuring, and on what devices?
Bear in mind that the only valid speed measurement is with a wired connection to the Hub. WiFi speeds are affected by local conditions, but there are things that can be done to improve them.
Mancjames
Message 3 of 8
Hey
Thanks for coming back to me :-)
Its intermittent to be honest- it's a wired connection with my ps4 and at times it will be fine but then it'll go down to about 20mb/s and I'll have to restart the router. It just keeps happening and a bit unsure why tbh as have it on a wired connection
  • 11.38K
  • 1.04K
  • 2.43K
griffin
Message 4 of 8
The rest of the downstream stats would be useful.
Mancjames
Message 5 of 8
Sorry bit new to all this, which tab would I get this from in the router?
  • 3.53K
  • 423
  • 1.12K
Message 6 of 8
From the Downstream tab that you have already accessed, you just need to scroll down and capture all the figures.  There should be two lots of 24 channels, one with headings:
and one with headings:
______________________
Scott
My setup: Vivid 200 Optical fibre with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
Mancjames
Message 7 of 8
Sorry this took so long! Had to find a computer as it wouldn't show on my phone.
11947500004.340256 qam8
21787500004.840256 qam6
31867500004.640256 qam7
4202750000440256 qam9
52107500003.940256 qam10
62187500003.740256 qam11
72267500003.540256 qam12
82347500003.240256 qam13
92427500003.240256 qam14
10250750000340256 qam15
112587500002.940256 qam16
122667500002.740256 qam17
132747500002.540256 qam18
142827500002.440256 qam19
152907500002.440256 qam20
162987500002.540256 qam21
173067500002.240256 qam22
183147500002.240256 qam23
19322750000240256 qam24
204027500001.240256 qam25
21410750000138256 qam26
224187500000.938256 qam27
234267500000.938256 qam28
244347500000.738256 qam29
1Locked40.924125
2Locked40.310623
3Locked40.99918
4Locked40.9232228
5Locked40.35494631
6Locked40.320427142815303
7Locked40.32461852105600
8Locked40.320931
9Locked40.922321
10Locked40.3196161
11Locked40.3194104
12Locked40.366144
13Locked40.96942
14Locked40.35527
15Locked40.36274
16Locked40.35325
17Locked40.35835
18Locked40.35223
19Locked40.35792
20Locked40.35224
21Locked38.95417
22Locked38.98116
23Locked38.94816
24Locked38.95112
  • 594
  • 23
  • 52
Message 8 of 8
Hi Mancjames
So we can take a closer look at this for you I'm going to send you a PM to confirm some account details.
Tom_S
