peelmeister
  • 14
Message 1 of 15
Speed issues
What appears to be a common theme, I’m not getting the advertised speeds I Should be getting.
I should be getting 350, although sometimes I’m lucky to get into 3 figures
Ive gone through all the self help stuff, reset the router etc and as requested attached are the Downstream, Upstream and Network log
Can anyone help??
Cheers
Andrew551C0CEC-3925-445E-8FAF-A56984CE074E.jpeg65264D90-008E-44FA-9C48-84EDA89EF451.jpegAAC2D46F-564D-4E59-BFA2-55C13F2CD19B.jpeg8575C522-7900-49A1-8528-3B5FF4BEE066.jpegEAFB73E8-03FE-41F0-AB3F-474C55323062.jpeg
Anonymous
Not applicable
Message 2 of 15
Re: Speed issues
Do you get full speed on wired devices?
I can't see the images as yet since they need approving.
peelmeister
  • 14
Message 3 of 15
Re: Speed issues
Yes, I have.
ive linked up my laptop directly and still the speeds are down/intermittent
Anonymous
Not applicable
Message 4 of 15
Re: Speed issues
@peelmeister wrote:
Yes, I have.
Ok.
Could you access your router using http://192.168.0.1/ or http://192.168.100.1 for modem mode . You shouldn't need log in, select the 'Check Router Status' option and paste your 'Downstream', 'Upstream', and 'Network Log' tabs? Please copy/paste this data as text, split between multiple posts (Sometimes you have to click 'Post' twice due to an error message).
We can have a look for any oddities in the stats.
peelmeister
  • 14
Message 5 of 15
Re: Speed issues
Ok, I’ll text the data. That’s what the pictures are of that are waiting to be checked.
give me a few minutes.
thank you
peelmeister
  • 14
Message 6 of 15
Re: Speed issues
14027500001.237256 qam25
22187500002.436256 qam11
32267500001.936256 qam12
42347500001.736256 qam13
52427500001.736256 qam14
62507500001.536256 qam15
72587500001.237256 qam16
82667500001.436256 qam17
92747500001.736256 qam18
102827500002.436256 qam19
112907500002.737256 qam20
122987500002.936256 qam21
133067500002.537256 qam22
143147500002.437256 qam23
153227500002.537256 qam24
164107500001.436256 qam26
174187500001.237256 qam27
184267500000.937256 qam28
194347500001.237256 qam29
204427500001.537256 qam30
214507500001.437256 qam31
224587500000.737256 qam32
234667500000.237256 qam33
244747500000.237256 qam34
1Locked37.310
2Locked36.650
3Locked36.350
4Locked36.660
5Locked36.640
6Locked36.6120
7Locked37.380
8Locked36.350
9Locked36.370
10Locked36.660
11Locked37.360
12Locked36.650
13Locked37.350
14Locked37.340
15Locked37.300
16Locked36.6140
17Locked37.360
18Locked37.300
19Locked37.660
20Locked37.650
21Locked37.350
22Locked37.350
23Locked37.6110
24Locked37.300
peelmeister
  • 14
Message 7 of 15
Re: Speed issues
1394000005.1512064 qam2
2462000005.1512064 qam1
3326000005.1512064 qam3
4257999015.1512064 qam4
3ATDMA0000
4ATDMA0000
peelmeister
  • 14
Message 8 of 15
Re: Speed issues
05/09/2020 15:22:13noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/09/2020 15:19:57Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:35criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/09/2020 19:33:35ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/09/2020 05:39:47noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2020 20:56:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2020 17:45:1noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2020 11:57:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/09/2020 17:31:5noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/09/2020 19:22:23ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/09/2020 15:26:5ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/09/2020 11:32:11noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/09/2020 11:29:50ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/09/2020 08:47:20noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/09/2020 08:30:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/09/2020 06:49:21noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/09/2020 06:48:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/09/2020 06:01:8noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 11:52:21ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 09:54:16noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Anonymous
Not applicable
Message 9 of 15
Re: Speed issues
Your upstream power levels are very high:
The HUB 3 reports a decimal out so the above values are actually 51 dBmV.
peelmeister
  • 14
Message 10 of 15
Re: Speed issues
Thanks for the reply, but i'm a complete novice - is that a good thing or bad thing?
