pastorthomas
Message 1 of 8
Speed evening problems
I have been getting slow speed starting Monday 9th November. It only happens in the evening. During the day my speed is perfect, 200mb. I thought Virgin would have fixed it by now, but today, once again, for the 5th day, its crazy at 9mb. No where near 50%.  Here are my info from modem:
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
411000000
1
35
256 qam
1
2
419000000
0.7
35
256 qam
2
3
427000000
1.4
35
256 qam
3
4
435000000
1.5
36
256 qam
4
5
443000000
1.7
36
256 qam
5
6
451000000
1.7
36
256 qam
6
7
459000000
1.4
36
256 qam
7
8
467000000
1
36
256 qam
8
9
475000000
1.2
36
256 qam
9
10
483000000
1.2
36
256 qam
10
11
491000000
0.7
36
256 qam
11
12
499000000
0.9
36
256 qam
12
13
507000000
0.7
36
256 qam
13
14
515000000
1
36
256 qam
14
15
523000000
1.4
36
256 qam
15
16
531000000
1.2
36
256 qam
16
17
539000000
0.4
37
256 qam
17
18
547000000
0.2
37
256 qam
18
19
555000000
1
36
256 qam
19
20
563000000
1
37
256 qam
20
21
571000000
1.2
37
256 qam
21
22
579000000
0.7
37
256 qam
22
23
587000000
0.4
37
256 qam
23
24
595000000
0.5
36
256 qam
24
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
35.7
2823
0
2
Locked
35.7
1589
2
3
Locked
35.5
1973
0
4
Locked
36.3
1195
0
5
Locked
36.3
657
1
6
Locked
36.3
318
11
7
Locked
36.3
445
0
8
Locked
36.6
422
14
9
Locked
36.6
273
0
10
Locked
36.3
346
0
11
Locked
36.6
402
11
12
Locked
36.6
306
0
13
Locked
36.3
262
0
14
Locked
36.6
297
0
15
Locked
36.6
250
5
16
Locked
36.6
305
0
17
Locked
37.3
297
10
18
Locked
37.3
312
20
19
Locked
36.6
253
0
20
Locked
37.6
269
1
21
Locked
37.3
215
17
22
Locked
37.3
276
0
23
Locked
37.6
318
0
24
Locked
36.6
386
18
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
39400000
3.925
5120
64 qam
2
2
46200126
4
5120
64 qam
1
3
32600000
3.9
5120
32 qam
3
4
25800000
3.9
5120
32 qam
4
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
Time
Priority
Description
13/11/2020 21:14:32
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 21:12:25
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 20:58:15
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 18:54:12
critical
10/11/2020 08:58:14
Error
09/11/2020 05:04:7
critical
06/11/2020 21:39:32
notice
06/11/2020 21:38:39
Warning!
06/11/2020 21:27:46
critical
06/11/2020 21:24:29
notice
SW download Successful - Via Config file
06/11/2020 21:22:0
notice
SW Download INIT - Via Config file
01/01/1970 00:01:54
critical
06/11/2020 20:29:49
Error
03/11/2020 08:42:26
critical
03/11/2020 08:29:49
Error
01/11/2020 05:52:27
critical
30/10/2020 20:29:49
Error
30/10/2020 15:17:8
critical
27/10/2020 16:38:0
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/10/2020 16:37:55
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Tags (1)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 8
Re: Speed evening problems
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 8
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
pastorthomas
Message 4 of 8
Thanks. I have been using Speedtest every day. See the attachedScreenshot 2020-11-13 at 20.59.50.png
Tags (1)
Anonymous
Not applicable
Message 5 of 8
Two of your upstream channels are not showing the correct QAM value, which shows there could be a line fault:
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
39400000
3.925
5120
64 qam
2
2
46200126
4
5120
64 qam
1
3
32600000
3.9
5120
32 qam
3
4
25800000
3.9
5120
32 qam
4
Katie_WT
  • 5.02K
  • 304
  • 569
Message 6 of 8
Hi there @pastorthomas
Thanks for popping back with your speedtest; was this over a direct wired connection?
I have located your account from here and can see it's been over a week since your last reboot - we have no known area issues showing form this end and your Upstream channels seem to be showing the correct stats at the time of checking.
All signal levels are within the parameters we would expect for your package and no errors are showing. We can see that you're currently in Modem mode; do you  have the same issue when in router mode over a wired connection?
Have you been able to set up a BQM for us as suggested?
Please do pop back with updates if you're still having issues.
Cheers
Katie - Forum Team
  • 23.78K
  • 2.52K
  • 4.31K
Message 7 of 8
As said post up the link to the "share live graph" - its in red under your own BQM
mccarthysimon1
Message 8 of 8
Today and currently have very slow download speeds at average 30 when I subscribe to 350. It interfered with work today and status says no problems. Usually very good at around 400.
Tags (1)
