swellback
Message 1 of 5
Speed dropping drastically many times a day
We are on the M200 broadband package and have been suffering multiple drop outs daily for a few months. There is no local problem reported in service status though a lot of out neighbours are having the same problem. My download speed can drop from 200 to 0.2 Mbps at different times of day. There is no pattern, just that it's bound to happen every day.
I've followed the rebooting, resetting advice many times and it hasn't helped. I now have to keep my phone handy in order to tether my mac to it when it drops out at critical times while working.
I will try and attach the requested log files in another message as every time I try to post this it says "correct highlighted errors and try again" ...there is nothing highlighted.
Thanks.
swellback
Message 2 of 5
Re: Speed dropping drastically many times a day
14027500000.740256 qam30
22027500005.940256 qam9
32107500005.540256 qam10
42187500005.440256 qam11
52267500005.340256 qam12
62347500005.340256 qam13
7242750000540256 qam14
82507500004.840256 qam15
92587500004.540256 qam16
102667500004.440256 qam17
112747500004.340256 qam18
12282750000440256 qam19
132907500003.940256 qam20
142987500003.740256 qam21
153067500003.240256 qam22
16314750000340256 qam23
173227500003.240256 qam24
18330750000340256 qam25
193707500001.740256 qam26
203787500001.440256 qam27
213867500001.240256 qam28
22394750000140256 qam29
234107500001.240256 qam31
24418750000140256 qam32
1Locked40.91220
2Locked40.9610
3Locked40.3710
4Locked40.3630
5Locked40.9570
6Locked40.9870
7Locked40.9680
8Locked40.91010
9Locked40.9420
10Locked40.3730
11Locked40.9650
12Locked40.3570
13Locked40.3820
14Locked40.3790
15Locked40.3730
16Locked40.9860
17Locked40.31400
18Locked40.3510
19Locked40.91530
20Locked40.31080
21Locked40.91340
22Locked40.31670
23Locked40.31040
24Locked40.31200
swellback
Message 3 of 5
13260000038.8512064 qam13
23940000039.3512064 qam12
34620000039.8512064 qam11
45370000040.3512064 qam10
1ATDMA0080
2ATDMA0020
3ATDMA0030
4ATDMA0050
swellback
Message 4 of 5
25/11/2020 15:06:39noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/11/2020 15:05:58Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/11/2020 10:12:38noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2020 14:16:15noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2020 14:16:15ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/11/2020 05:30:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/11/2020 02:16:15noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/11/2020 02:16:15ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 21:05:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 14:16:15noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 14:16:15ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 14:07:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 02:16:15noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 02:16:15ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 13:59:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 14:16:14noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 14:16:14ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 03:34:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 03:33:44criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 03:33:37criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 5
Your Downstream Power Levels individually are all within spec but, the differential between the lowest at +1.0dBmV and the highest at +5.9dBmv is too great.
This will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
