Harrycot
  • 6
Message 1 of 5
Speed dropping 90%
So a few months back i was having issues with my router, which stopped after a few reboots, however the issue has returned and it seems to have returned. i have tried the fix i used before but that has not helped at all.
My logs from my router are:
Network LogTime Priority Description
31/12/2020 17:25:6Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2020 17:24:43noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2020 17:17:12Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2020 17:17:7noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2020 11:22:46Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2020 11:21:13Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2020 11:08:4Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2020 11:07:33Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2020 11:04:2Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2020 10:30:53Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2020 10:30:52Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2020 10:24:43Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2020 10:24:29Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2020 10:24:29Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/12/2020 10:36:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/12/2020 22:25:32Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/12/2020 20:02:2noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/12/2020 20:01:59Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/12/2020 20:01:46noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
any help would be greatly appreciated.
Thank you
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 5
Re: Speed dropping 90%
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 5
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
A Guru will be along soon to decipher the info
Harrycot
  • 6
Message 4 of 5
1267000000-0.937256 qam17
21390000001.737256 qam1
31470000001.537256 qam2
41550000001.237256 qam3
51630000000.737256 qam4
61710000000.737256 qam5
71790000000.437256 qam6
81870000000.437256 qam7
9195000000037256 qam8
10203000000-0.237256 qam9
11211000000-0.237256 qam10
12219000000-0.528256 qam11
13227000000-0.736256 qam12
14235000000-0.737256 qam13
15243000000-137256 qam14
16251000000-1.237256 qam15
17259000000-137256 qam16
18275000000-137256 qam18
19283000000-137256 qam19
20291000000-1.437256 qam20
21299000000-1.437256 qam21
22307000000-1.537256 qam22
23315000000-1.737256 qam23
24323000000-237256 qam24
1Locked37.619366911
2Locked37.3102211326
3Locked37.696010931
4Locked37.3102210181
5Locked37.610089236
6Locked37.610249228
7Locked37.610749979
8Locked37.310119334
9Locked37.610989560
10Locked37.311059010
11Locked37.313378595
12Locked28.62643052113996578
13Locked36.3653124207
14Locked37.614227861
15Locked37.615247306
16Locked37.316068114
17Locked37.316136403
18Locked37.618236131
19Locked37.619876412
20Locked37.618955751
21Locked37.321685652
22Locked37.621385534
23Locked37.319014820
24Locked37.321804699
14620000047512064 qam3
23940000046.8512064 qam4
32580000046.8512064 qam6
43260000047512064 qam5
3ATDMA0000
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt057-b.cm
SFID670296
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID670295
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
Harrycot
  • 6
Message 5 of 5
My BQM
