on 31-01-2022 12:01
Should be getting 200Mb. I'm using Deco P9 as router with two other satellite P9s in mesh wifi. Today I'm getting 30Mbps download and 21Mbps upload, which is considerably better than usual, but clearly nowhere near what I expect to get. Have tried swapping P9s, rebooting in order, etc. Getting nowhere on TPLink help sites, so wondering if anyone here can help?
on 31-01-2022 16:07
on 02-02-2022 15:30
Many thanks for your reply. I have two people working from home most days, so I'm just waiting for a chance to try out your suggestions.
on 02-02-2022 15:35
The issue I would have with this is the hybrid nature of this device. It uses powerline technology and that in itself is not good as it uses the house wiring to transmit the signal.
I would remove any of the mesh units you have that use the powerline and just use the wifi mesh as a test. Personally I would get the wifi only triband mesh or go with Access Points.
