  • 524
  • 67
aceado
Fibre optic
Message 71 of 98
Re: Speed and latency problems
@modteam is there still no updates of what's going on and when issue will be fixed? this will make it two months of having these issues and still no fix!
___________________________________________
i might be harsh but i will get to the point unlike some!
internet: 350/20 area: 014 status: suffering from weird peak issues.
at virgin we like to fob you off with little as possible!
  • 524
  • 67
aceado
Fibre optic
Message 72 of 98
after thinking and looking more into this it seems i might have another idea where the fault could be due to which route it takes as some of these are quite common when it comes to which server is being used. so during peak time it seems there's some sort of issue which seems to be very hard to find my guess is down to the network side with
brad-core-2b-xe-300-0
brad-core-2b-xe-303-0
brad-core-2b-xe-020-0
brad-core-2a-xe-020-0
i understand some of this might not matter at all but i would highly suggest looking into the network which i've highlighted and see what results you find. what i can say is between september 30th until october 5th was the only time it was fine i do hope this helps is some manner since issue been going on for two months now even the same results of the bqm shows the same on both my home connection and the local ctms gateway.
my idea is if it takes a certain route each time and its slow there must be some sort of fault on it... i did this by trace routering a few examples below from speedtest.net and twitch this is only a small sample but i'm very sure something will be found @modteam @Nicola_C
Tracing route to http-speedtest4.thinkbroadband.com [80.249.103.8]
over a maximum of 30 hops:
1 2 ms 1 ms 1 ms 192.168.0.1
2 11 ms 10 ms 8 ms 10.187.16.1
3 11 ms 10 ms 9 ms brad-core-2b-xe-303-0.network.virginmedia.net [82.2.241.109]
4 * * * Request timed out.
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 44 ms 45 ms 48 ms eislou2-ic-2-ae0-0.network.virginmedia.net [62.254.84.62]
9 45 ms 45 ms 43 ms linx-gw2.thdo.ncuk.net [195.66.236.240]
10 40 ms 42 ms 38 ms te2-1-9.star10g.bdr-rt1.thn.ncuk.net [80.249.97.18]
11 39 ms 44 ms 42 ms speedtest4.thinkbroadband.com [80.249.103.8]
Trace complete.
Tracing route to pingbox1.thinkbroadband.com [80.249.99.164]
1 1 ms 1 ms 1 ms 192.168.0.1
2 9 ms 9 ms 9 ms 10.187.16.1
3 11 ms 14 ms 11 ms brad-core-2b-xe-300-0.network.virginmedia.net [82.2.241.105]
8 41 ms 33 ms 66 ms eislou2-ic-2-ae0-0.network.virginmedia.net [62.254.84.62]
9 34 ms 33 ms 36 ms linx-gw2.thdo.ncuk.net [195.66.236.240]
10 44 ms 50 ms 43 ms po4-31.core-rs2.thdo.ncuk.net [80.249.97.85]
11 45 ms 49 ms 44 ms pingbox1.thinkbroadband.com [80.249.99.164]
Trace complete.
Tracing route to speedtest.bytemark.co.uk [5.153.225.223]
2 10 ms 10 ms 14 ms 10.187.16.1
3 17 ms 27 ms 37 ms brad-core-2b-xe-303-0.network.virginmedia.net [82.2.241.109]
6 31 ms 32 ms 31 ms tcma-ic-2-ae9-0.network.virginmedia.net [62.253.174.178]
7 38 ms 43 ms 38 ms te0-1-0-3.cr3.man.bytemark.co.uk [195.66.244.12]
8 44 ms 51 ms 45 ms te0-0-2-0.cr2.lds.bytemark.co.uk [91.223.58.71]
9 40 ms 39 ms 35 ms te0-1-0-17.cr3.yrk.bytemark.co.uk [91.223.58.35]
10 35 ms 33 ms 35 ms po1.ar1.dc1.yo26.yrk.bytemark.co.uk [91.223.58.29]
11 35 ms 43 ms 35 ms speedtest.bytemark.co.uk [5.153.225.223]
Trace complete.
Tracing route to speedtest.razorblue.net.uk [86.105.225.194]
2 11 ms 9 ms 9 ms 10.187.16.1
3 25 ms 11 ms 22 ms brad-core-2b-xe-303-0.network.virginmedia.net [82.2.241.109]
5 19 ms 21 ms 37 ms telw-ic-4-ae0-0.network.virginmedia.net [62.254.84.70]
6 16 ms 16 ms 15 ms ae-0-0.bb1.lon1.razorblue.net.uk [195.66.226.122]
7 45 ms 45 ms 45 ms xe-0-0-2.bb1.lds1.razorblue.net.uk [86.105.225.132]
8 46 ms 49 ms 45 ms xe-0-1-2-25.vc1.lds1.razorblue.net.uk [185.13.246.12]
9 44 ms 51 ms 44 ms speedtest.razorblue.net.uk [86.105.225.194]
Trace complete.
Tracing route to lon.host.speedtest.net [95.87.111.214]
2 10 ms 9 ms 14 ms 10.187.16.1
3 10 ms 10 ms 9 ms brad-core-2b-xe-020-0.network.virginmedia.net [82.2.241.113]
6 47 ms 45 ms 47 ms 86.85-254-62.static.virginmediabusiness.co.uk [62.254.85.86]
7 45 ms 39 ms 42 ms 213.46.174.46
8 21 ms 19 ms 19 ms structuredcommunications.demarc.cogentco.com [149.14.248.42]
9 40 ms 41 ms 54 ms ae-te-thn-b.structuredcommunications.co.uk [95.87.111.202]
10 36 ms 34 ms 34 ms te0-1.speedtest.structuredcommunications.co.uk [95.87.111.214]
Trace complete.
Tracing route to speedtest-net1.rapidswitch.co.uk [78.129.139.190]
2 11 ms 10 ms 9 ms 10.187.16.1
3 12 ms 11 ms 10 ms brad-core-2b-xe-303-0.network.virginmedia.net [82.2.241.109]
6 20 ms 18 ms 16 ms tcl5-ic-6-ae0-0.network.virginmedia.net [62.254.85.66]
7 16 ms 16 ms 27 ms be20.asr01.thn.as20860.net [195.66.224.207]
8 17 ms 18 ms 16 ms po111.net1.north.dc5.as20860.net [62.233.127.174]
9 18 ms 17 ms 17 ms po2-30.bor2.dc5.as20860.net [212.84.162.158]
10 18 ms 17 ms 18 ms e1-45.lea101.1uf.dc5.as20860.net [212.84.181.104]
11 17 ms 16 ms 15 ms 78.129.139.1
12 18 ms 17 ms 15 ms smtp2.myff.org [78.129.139.190]
Trace complete.
Tracing route to mirror.i3d.net [213.163.76.200]
2 9 ms 9 ms 13 ms 10.187.16.1
3 14 ms 12 ms 10 ms brad-core-2b-xe-020-0.network.virginmedia.net [82.2.241.113]
8 39 ms 42 ms 51 ms tclo-ic-3-ae0-0.network.virginmedia.net [212.250.25.62]
9 44 ms 39 ms 37 ms 20ge.linx-jnpr.th-n.i3d.net [195.66.225.146]
10 47 ms 45 ms 45 ms 30ge.cr0-lr0.smartdc.rtm.i3d.net [109.200.218.154]
11 56 ms 53 ms 51 ms 100ge.br3-cr0.smartdc.rtm.i3d.net [109.200.218.165]
12 48 ms 59 ms 48 ms hosted-by.i3d.net [213.163.76.200]
Trace complete.
Tracing route to video-edge-c67f20.lhr03.abs.hls.ttvnw.net [185.42.206.232]
2 9 ms 9 ms 15 ms 10.187.16.1
3 32 ms 33 ms 40 ms brad-core-2a-xe-020-0.network.virginmedia.net [82.2.241.89]
6 42 ms 44 ms 42 ms tele-ic-6-ae2-0.network.virginmedia.net [62.253.174.86]
7 reserved.justin.tv [192.16.69.42] reports: Destination net unreachable.
Trace complete.
Tracing route to video-weaver.lhr03.hls.ttvnw.net [192.108.239.108]
2 10 ms 12 ms 9 ms 10.187.16.1
3 16 ms 13 ms 12 ms brad-core-2b-xe-303-0.network.virginmedia.net [82.2.241.109]
5 23 ms 39 ms 16 ms tcl3-ic-1-ae0-0.network.virginmedia.net [212.43.163.198]
6 reserved.justin.tv [192.16.69.42] reports: Destination net unreachable.
Trace complete.
here's some random speedtests i've done and the servers that i've used for testing with and for the above traceroutes above
  • 524
  • 67
aceado
Fibre optic
Message 73 of 98
here's a fellow up since tuesday to keep people in the loop. as you can see on tuesday the issue was still there Smiley Sad
however for the past two days (wed/thurs) its been back to normal but it makes you wonder how long it will last or even what has changed for it to be fixed in the first place @modteam ,@Nicola_C
2f9fa01c91f639596374c98f08ab6bec154e53bd-30-10-201830/10f055cceddf9c929bcaf3c8f20a55ce7c99516847-30-10-2018
0cb85797f865e309a5973db5715beb5f02c43420-31-10-2018b5f63c0ed6caded94b882d8cab6487554f295a22-31-10-2018
31/10
216684c0590a0eb6042e059cf215667a40b045b7-01-11-2018
01/116b6d2597ae2654667059a059c09a36344f4dfe5f-01-11-2018
  • 19
MSCU990
Message 74 of 98
Thanks aceado, will keep an eye on mine this evening to see how it performs.
  • 105
  • 7
rockies
Dialled in
Message 75 of 98
@Aceado
Can confirm mines was ok last night and seems ok at the moment. Just hope it doesn't do what it did last time and last only a few days.
1st
2nd
  • 19
MSCU990
Message 76 of 98
Don’t want to speak too soon but mine also seems to be working fine this evening.
  • 524
  • 67
aceado
Fibre optic
Message 77 of 98
still looking good without any issues which is great news
  • 19
MSCU990
Message 78 of 98
Still all working ok for me. Same for you guys?
  • 105
  • 7
rockies
Dialled in
Message 79 of 98
Still working here. Still slowing down a little but still nothing like before.
  • 524
  • 67
aceado
Fibre optic
Message 80 of 98
I can also confirm not having anymore issues but it does make you wonder what caused the problem and how was it fix so we know for the next time @modteam
