  • 524
  • 67
aceado
Fibre optic
Message 61 of 98
Re: Speed and latency problems
still no change on both my connection nor the ctms gateway
22/10360d80174e77dd7877516f8d5e90dc7e5c4708f5-22-10-2018
9b06e3ffd933e29782eee54f0ecb229ff0a7f268-22-10-2018
e718975f97fa6e28c5b7df138c22eee886072eb0-23-10-201823/10
f7f57732bcc3a09a221a51426996b990b14f29f3-23-10-2018
24/10eb5cbe565c507fe355e863169f2eb337a0e26dcf-24-10-2018
e95f103d67a73d537372a248089384109423d91c-24-10-2018
___________________________________________
i might be harsh but i will get to the point unlike some!
internet: 350/20 area: 014 status: suffering from weird peak issues.
at virgin we like to fob you off with little as possible!
  • 10.87K
  • 406
  • 1.24K
Forum Team (Retired) Nicola_C
Message 62 of 98
Morning @aceado
Is it still happening? Please would you keep the graphs coming or kindly post the live link. We continue to feed this back to networks and thoroughly appreciate your patience and help.
Thank you
Nicola
Virgin Media Forum Team
  • 19
MSCU990
Message 63 of 98
Hi Samantha,
That is frustrating. Honestly, I believe this will be happening to many more people in the area but they are actually unaware of how to check what is going on themselves, and then obviously when they contact your customer support they are told there are no issues.
Unfortunately I haven't had good experiences with your call centre myself regarding the issue. Are you able to test my line? I use modem mode already and every time I call to discuss my issues the call centre ask me to put the hub back into router mode, which is also frustrating.
  • 524
  • 67
aceado
Fibre optic
Message 64 of 98
@Nicola_C wrote:
Morning @aceado
Thank you
yes its still happening with not a single change at all which is just beyond a joke!
here's a live link for the ctms gateway which will gave you a clear idea of what's going on
https://www.thinkbroadband.com/broadband/monitoring/quality/share/600e18cf4caa6b4409e5681ceba8b83f
  • 107
  • 7
rockies
Dialled in
Message 65 of 98
Still happening here.
Yesterday was my day off so was able to use broadband most of the day but as soon as it got to around 4pm the speed took a nose dive until it eventually gave out around 8ish (speed test gave <5mbps download)
heres my love link as well
https://www.thinkbroadband.com/broadband/monitoring/quality/share/1c96576c5a632739567d9825df3790365c...
  • 10.87K
  • 406
  • 1.24K
Message 66 of 98
Thanks aceado and rockies, all fed back appropriately, thank you for your continued patience.
Nicola
  • 69
  • 17
Gary333
Dialled in
Message 67 of 98
Still problems here. An 'Engineer' came around on Wednesday and after scratching his head decided the tap in the cabinet was faulty so changed to another tap pressumably (although he had to be talked through how to do this so not sure i'd trust this diagnosis). All changing the tap has done is put the power levels up to 8-9.5dbmv so no doubt i will now get told by the unhelpful desk is 'your power levels are causing the problem' and the virgin media roundabout of misery continues.
BTW New Delhi call centre manager (Raj) tells me that he cannot escalate this issue to networks as i quote 'that is for the engineer to do'. So apparently a customer is left to argue the toss with the engineers, who obviously make a minor change and break something else or at least put off the problem long enough for t to be someone elses problem.
Thursday / Friday / This Morning
08b6397ccd17bf936f8f36cf4aef969765c89388-25-10-2018
1c7733e0585287417a17e0d8b30dfdc8c4a611e6-26-10-2018
b2f9a292e2a1a9fd89244c720b4d54c8810adae1
  • 5
Maku32
Message 68 of 98
Hello. Thanks god i found this thread, i also have massive problems with my broadband since like 1 month? exacly same problem like @aceado and @rockies. Every day after 6pm my download speed is going down to 1-4 Mbps, my broadband is Vivid 200Mbps. Im also from Doncaster, Dn2 area.
  • 5
Maku32
Message 69 of 98
21:01 my speedtest results
  • 107
  • 7
rockies
Dialled in
Message 70 of 98
Still no better, its coming up to 6pm and once again my speeds are slow. This is now trying my patience and have started looking at other providers. ALso the red parts on the BBQM are nothing to do with anything on my side. That's just when the broadband decided not to work totally
27th October
28th October
