  • 105
  • 7
rockies
Dialled in
Message 31 of 98
Re: Speed and latency problems
Hi Ralph_r
still same here. I have given you the url to a live graph
https://www.thinkbroadband.com/broadband/monitoring/quality/share/14bc0a3236412c48a3692a036a96241bf2...
  • 524
  • 67
aceado
Fibre optic
Message 32 of 98
i can also confirm the same as well with no changes
___________________________________________
i might be harsh but i will get to the point unlike some!
internet: 350/20 area: 014 status: suffering from weird peak issues.
at virgin we like to fob you off with little as possible!
  • 11.6K
  • 417
  • 1.02K
Message 33 of 98
My guess would be a routing QoS issue
Is your latency low if you ping 194.168.4.100? should be 10ms you can also run tracert 80.249.99.164
  • 105
  • 7
rockies
Dialled in
Message 34 of 98
I had an engineer out on the 27th. When he was here the connection disconnected and he stated it was a network snr problem that would be fixed on the 1st October (for once he was right as well) then on the 6th it’s just been getting worse and worse. Unable to stream or download anything, web pages are a joke as well as they take anything for a few seconds up to a few minutes. Seems like it happening between the hours of 4pm and midnight so looking like it could be the over subscribing issue I had for over 2 years previously.
  • 524
  • 67
aceado
Fibre optic
Message 35 of 98
the issues ive posted shows both my connection and the ctms which both are showing 100% the same you can even see message #14 confirms that im monitoring the ctms gateway
  • 524
  • 67
aceado
Fibre optic
Message 36 of 98
here's mine from 10/101fae7865114714ba522092685365ea2dfccfb17d-10-10-2018
 @Ralph_R it seems when i do a traceroute to 80.249.99.164 it seems to leave brad-core-2b same with every other website that i test so i wonder if the same issue thats on brad-core-2a is also on brad-core-2b
ca458d7a66d4ff5bfa9a7e59ab8a9542312fff87-10-10-2018and the ctms gateway
  • 105
  • 7
rockies
Dialled in
Message 37 of 98
@Ralph_R
Its getting worse can not even stream anything (youtube, netflix, virgin ondemand) and the internet is so slow. Plus dont know whats going on with this :-
  • 524
  • 67
aceado
Fibre optic
Message 38 of 98
here are the past two days which once again still just as bad with no changes at all
a26e511b81f024bc2062f9dd4f6ab7cdf369896c-12-10-201812/10
1e88e99941b23330fdda23c45ea52f678f67566f-12-10-2018
8d9ed49538eaa4032392a2fa64fbaaef9b8856eb-13-10-201813/10
c02b11f1dd738f8b699d4051a226ac908e9de1ba-13-10-2018
  • 147
  • 20
spankthemunkey1
Up to speed
Message 39 of 98
welcome to the world of virgin media,
i have been suffering non stop issues for nearly 10 years now, my newest issues of over subscription slow to virtually stop internet and a ping of 25ms from bristol to bristol ( joke in its self ), is not even going to be looked at until feb 2019. I am afraid its something you have to live with, they couldn't give a toss about the customers just their money.
i also have the issue with the super hub 3 puma 6 problems, by the way virgin say there is no issues with it, its fine but their tech teams say different, you get used to the constant lies from virgin crappy media.
Oh and before you say " why haven't you moved to someone else ", i have nobody else to go to in my area.
  • 105
  • 7
rockies
Dialled in
Message 40 of 98
Beyond a joke now.
Sites not working netflix, NowTV, Deezer, Youtube, none will stream at all. The BBQM is looking worse every day and now its not restricted to between 4-12, its happening most of the time. Here are my BBQM's from the last few days (had a change in IP address due to a power outage).
11th October
12th
13th
14th
