As you expect >100Mbps then connect a 1GB enabled computer/laptop, with up to date drivers, via a NEW and working Cat5e (or better) ethernet cable, directly to the Hub which you have put into “modem mode” (
https://www.virginmedia.com/help/virgin-media-hub-modem-mode ).
Test speeds at
https://speedtest.samknows.com/ - try on 2 different browsers one a new install.
If they are still low – boot you device into windows safe+networking mode to disable any potentially interfering software - and try again.
There are many posts on here where QoS software, unknown/flaky software, old network card drivers, corrupted browsers, bad cables or other connected devices are limiting speeds on tests.
Report back what that gets.
