  • 14
Speed Issues
Couple of things really, i am paying for 1gb from virgin, but when i do speedtest the most i have gotten in last 5 days is 327mb down now thats allot lower than i should be getting. Before i ring up (as for some reason they dont have chat which i prefer) can someone confirm which speedcheck site virgin will recognise. I used speedtest.net and fast.com as comparisons both give about the same.
And would anyone know the minimum speed im supposed to get, as if im paying for 1gb and dont even get 500 why would i be on this expensive package.
  • 3.54K
  • 569
  • 1.4K
Re: Speed Issues
VM recognise Speedtest.net and you must be measuring speed on a device connected to the hub by a Cat 5e, Cat 6 or Cat 7 network cable.
Under VM's minimum speed guarantee you should never see anything below 552 Mbps, but in normal operation you should expect to consistently see 1117-1145 Mbps.
You've been taken in by VM's marketing? There's a question only you can answer, based on what actual uses might usefully requires 1 Gbps.
