  • 10
darren-w-gray
Message 1 of 5
Speed Issues
Morning Collective.
I have noticed a general degradation in my t'Interweb connection over the last few weeks or so. Occasional drops in connection while doing things with software like OBS, Skype, FTP. Then came blips in online games like Apex Legends, etc.
I am consistently seeing 50Mbps - 75Mbps reported by speedtest (multi and single) for my 200Mbps connection, Cat6 ethernet to the hub, minimal loading from other devices. This is both during the day, the peak and right now at 5am.
The only thing I note in the network log that might be relevant (and occurs a few times in the recording log) is:
05/03/2019 14:01:33	critical	No Ranging Response received - T3 time-out;CM-MAC=[removed];CMTS-MAC=[removed];CM-QOS=1.1;CM-VER=3.0;
I thought originally that it would be because I moved the TV to Sky after the UKTV farce, then I remembered I still have it, but it is just permanently unplugged...
[sorry humor at 5am is lacking as it has not quite woken up yet]
Anyway, ideas are welcome and the router output below in case that helps. no changes have been made to the wiring to the router or router location etc in a few months.
Channel	Frequency (Hz)	Power (dBmV)	SNR (dB)	Modulation	Channel ID
1	675000000	1.7	40	256 qam	30
2	459000000	-1.5	38	256 qam	7
3	467000000	-1.5	38	256 qam	8
4	475000000	-2.2	38	256 qam	9
5	483000000	-2	38	256 qam	10
6	491000000	-1.9	38	256 qam	11
7	499000000	-1.5	38	256 qam	12
8	507000000	-1	38	256 qam	13
9	515000000	-0.5	38	256 qam	14
10	523000000	-0.4	40	256 qam	15
11	531000000	-1.4	38	256 qam	16
12	539000000	-1.7	38	256 qam	17
13	547000000	-1	38	256 qam	18
14	555000000	-0.7	38	256 qam	19
15	563000000	0	38	256 qam	20
16	571000000	0.4	38	256 qam	21
17	579000000	-0.4	38	256 qam	22
18	587000000	-1.5	38	256 qam	23
19	595000000	-2	38	256 qam	24
20	635000000	0	40	256 qam	25
21	643000000	-0.4	40	256 qam	26
22	651000000	0	38	256 qam	27
23	659000000	1	38	256 qam	28
24	667000000	1.7	40	256 qam	29
Channel	Locked Status	RxMER (dB)	Pre RS Errors	Post RS Errors
1	Locked	40.3	3422981	0
2	Locked	38.9	1109945	0
3	Locked	38.9	1266340	0
4	Locked	38.6	1357229	0
5	Locked	38.6	1443909	0
6	Locked	38.6	1483147	0
7	Locked	38.6	1711681	0
8	Locked	38.6	1996765	0
9	Locked	38.9	1783835	0
10	Locked	40.3	1882094	0
11	Locked	38.6	2047306	0
12	Locked	38.9	2225915	0
13	Locked	38.9	2448353	0
14	Locked	38.9	2785713	0
15	Locked	38.9	2782788	0
16	Locked	38.6	2748346	0
17	Locked	38.6	2792654	0
18	Locked	38.9	2798545	0
19	Locked	38.6	2759782	0
20	Locked	40.3	2751143	0
21	Locked	40.3	2845416	0
22	Locked	38.9	3457952	0
23	Locked	38.9	3415725	1
24	Locked	40.3	3347292	11
Channel	Frequency (Hz)	Power (dBmV)	Symbol Rate (ksps)	Modulation	Channel ID
1	39400097	4.3	5120	64 qam	6
2	25799961	4.3	5120	32 qam	8
3	32599976	4.3	5120	32 qam	7
4	46200051	4.35	5120	32 qam	5
Channel	Channel Type	T1 Timeouts	T2 Timeouts	T3 Timeouts	T4 Timeouts
1	ATDMA	0	0	0	0
2	ATDMA	0	0	0	0
3	ATDMA	0	0	0	0
4	ATDMA	0	0	0	0
  • 2.74K
  • 138
  • 386
jpeg1
Trouble shooter
Message 2 of 5
Re: Speed Issues
Your download levels are OK but there are many RS errors that the modem has generally corrected. They may be historical. But the upload channels are dropping back to 32qam which suggests a fault condition.
Suggested actions:
1. Check that the coax connections are tight.
2. Clear the error counters and check again after an hour or two.  They should all be nearly 0.
3. If you are still not getting the correct speed, call CS for a remote test and possible engineer visit.
  • 10
darren-w-gray
Message 3 of 5
Re: Speed Issues
Hi jpeg1;
I checked all the connections on and rebooted the router (I assumed this would reset the counters??) and have had variable success from a fairly immediate boost back to 200Mbps but also quite a few 50ish Mbps readings as well. The current stats are showing:
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
1	675000000	0.4	40	256 qam	30
2	459000000	-2.2	38	256 qam	7
3	467000000	-2.4	38	256 qam	8
4	475000000	-3	38	256 qam	9
5	483000000	-3	38	256 qam	10
6	491000000	-2.7	38	256 qam	11
7	499000000	-2.5	38	256 qam	12
8	507000000	-2	38	256 qam	13
9	515000000	-1.5	38	256 qam	14
10	523000000	-1.4	40	256 qam	15
11	531000000	-2.2	38	256 qam	16
12	539000000	-2.7	38	256 qam	17
13	547000000	-2.2	38	256 qam	18
14	555000000	-1.7	38	256 qam	19
15	563000000	-1	38	256 qam	20
16	571000000	-0.7	38	256 qam	21
17	579000000	-1.5	38	256 qam	22
18	587000000	-2.9	38	256 qam	23
19	595000000	-3.2	38	256 qam	24
20	635000000	-1.4	40	256 qam	25
21	643000000	-1.7	38	256 qam	26
22	651000000	-1.5	38	256 qam	27
23	659000000	-0.2	38	256 qam	28
24	667000000	0.4	40	256 qam	29
1	Locked	40.3	3658836	58
2	Locked	38.9	1175671	172
3	Locked	38.9	1345274	124
4	Locked	38.9	1443009	133
5	Locked	38.6	1542548	192
6	Locked	38.9	1580136	116
7	Locked	38.9	1819036	73
8	Locked	38.9	2113849	78
9	Locked	38.6	1896764	71
10	Locked	40.3	1999482	102
11	Locked	38.6	2174275	73
12	Locked	38.6	2355619	54
13	Locked	38.9	2609135	98
14	Locked	38.6	2970037	62
15	Locked	38.9	2964825	35
16	Locked	38.6	2935127	66
17	Locked	38.9	2985613	86
18	Locked	38.6	2993342	24
19	Locked	38.9	2946190	128
20	Locked	40.3	2932274	38
21	Locked	38.9	3030522	61
22	Locked	38.9	3701362	34
23	Locked	38.9	3646844	29
24	Locked	40.3	3582859	68
Refresh data
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1	39400026	4.25	5120	64 qam	6
2	25799991	4.35	5120	32 qam	8
3	32599959	4.4	5120	32 qam	7
4	46199986	4.35	5120	32 qam	5
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1	ATDMA	0	0	0	0
2	ATDMA	0	0	0	0
3	ATDMA	0	0	0	0
4	ATDMA	0	0	0	0
There are two other things which may be of note as well:
* I use a Samsung Galaxy S7, which continually drops the WiFi signal regardless of where I am. I could be sat right next to the router and the Android WiFi with an exclamation mark symbol appears and I have to cycle my handsets WiFi. Wife is reporting similar on a mid-tier device as well.
* I have a 10db attenuator in line at the box. It has been there since my original installation in 2014 and I left it there when the new box was sent out for a self-install.... is it worth trying it with that off?
Edited to add: These are the last error messages posted by the box:
13/03/2019 00:29:18	Error	DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/03/2019 08:21:51	Error	DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/03/2019 08:21:51	notice	DHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/03/2019 05:11:26	critical	No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
There were no entries recorded for yesterday (14th)
  • 2.74K
  • 138
  • 386
jpeg1
Trouble shooter
Message 4 of 5
Re: Speed Issues
The downstream levels are adequate, so removing the attenuator will not cure the problem
You have far too much noise on the incoming signal. That can be caused by a loose coax connection, but if you have checked that there is nothing more you can do.
From recent experience I think you would be better off phoning 150 to insist on an engineer visit, as official support on here has been somewhat degraded.
  • 72
  • 6
Message 5 of 5
Re: Speed Issues
Hi Darren-w-gray.
Thanks for letting us know about this. I appreciate that you're having intermittent connections.
For this, we need to send an engineer to take a further look on this. Have you already called us about this? If not, we can book this here and we can do this via online chat.
Let us know how you get on.
Ruel_C
