markymc1991
  • 13
Slow upload speed
Hi, I am struggling trying to fix my internet. I have gone through the steps on support, factory reset my hub, turned it off and on, made sure the cables are finger tight to no avail. See below links
Think broadband
Speedtest
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Slow upload speed
Can you please
markymc1991
  • 13
Downstream
1138750000338256 qam1
2146750000338256 qam2
3154750000338256 qam3
4162750000338256 qam4
51707500002.938256 qam5
61787500002.538256 qam6
71867500002.738256 qam7
8194750000338256 qam8
92027500002.738256 qam9
102107500002.738256 qam10
112187500002.438256 qam11
122267500002.538256 qam12
132347500002.538256 qam13
142427500002.438256 qam14
152507500002.438256 qam15
162587500002.438256 qam16
172667500002.538256 qam17
182747500002.238256 qam18
192827500002.438256 qam19
20290750000238256 qam20
212987500002.438256 qam21
22306750000238256 qam22
23314750000238256 qam23
243227500001.938256 qam24
1Locked38.916675872
2Locked38.916204133
3Locked38.912073709
4Locked38.612523823
5Locked38.914544532
6Locked38.618365120
7Locked38.913984085
8Locked38.613593588
9Locked38.911993184
10Locked38.912672925
11Locked38.611202405
12Locked38.98901663
13Locked38.98361439
14Locked38.97871227
15Locked38.96781054
16Locked38.9687909
17Locked38.96171019
18Locked38.96451063
19Locked38.66971169
20Locked38.68461092
21Locked38.97561210
22Locked38.98351511
23Locked38.68891540
24Locked38.68481509
markymc1991
  • 13
1394000004.254512064 qam4
2462000004.254512064 qam3
3536999564.3512064 qam2
4326000004.254512064 qam5
3ATDMA0000
4ATDMA0000
markymc1991
  • 13
22/10/2020 20:47:3criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 20:45:21noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 20:45:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 20:44:43noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 20:41:42Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 20:41:41criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 20:41:40Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 20:32:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 20:30:11noticeSW download Successful - Via Config file
22/10/2020 20:28:16noticeSW Download INIT - Via Config file
22/10/2020 20:25:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 20:23:40Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 14:57:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 05:38:57ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 02:10:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 17:30:10Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/10/2020 00:48:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/10/2020 17:38:57ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/10/2020 11:36:3criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/10/2020 09:47:20Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
markymc1991
  • 13
I will probably ring them tomorrow, since no one knows on here. Hopefully will get it sorted!
