louiseneeson
Just joined
Slow speed on new hub4
Hi I just upgraded to the hub 4 my internet speed on hub 3 was just over 200 mbps now it has dropped to anywhere between 40mbps and 80 mbps
how can I get back to 200mbps
thanks
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Slow speed on new hub4
What speeds do you get at >> Sam Knows Real Speed << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
