  • 10
infy101
Slow speed on VIVID 152 (Bracknell Area)
I've been noticing the speed of my VIVID 152 Optical Fibre is very slow - in fact ookla speed tests shows 11ms ping, but 5.22Mbps down and 11.16Mbps up. I've looked everywhere online and am not able to find any place to raise a ticket in order for an engineer to check it.
I've done the usual thing of restarting the hub and seems to work the same even after a full reset.
I remember last time it helped to post:
Item Status Comments
435000000
Locked
Ranged Upstream Channel (Hz)
39399983
Locked
Provisioning State
Online
Downstream:
1 435000000 4.6 38 256 qam 4
2 411000000 4.5 38 256 qam 1
3 419000000 4.4 38 256 qam 2
4 427000000 4.5 38 256 qam 3
5 443000000 5 38 256 qam 5
6 451000000 5.5 40 256 qam 6
7 459000000 5.5 40 256 qam 7
8 467000000 5.5 40 256 qam 8
9 475000000 5.3 40 256 qam 9
10 483000000 5.1 40 256 qam 10
11 491000000 5.1 38 256 qam 11
12 499000000 5 40 256 qam 12
13 507000000 4.9 38 256 qam 13
14 515000000 4.9 38 256 qam 14
15 523000000 4.8 38 256 qam 15
16 531000000 4.8 40 256 qam 16
17 539000000 4.5 38 256 qam 17
18 547000000 4.6 38 256 qam 18
19 555000000 4.6 38 256 qam 19
20 563000000 4.9 38 256 qam 20
21 571000000 5.1 40 256 qam 21
22 579000000 5.4 40 256 qam 22
23 587000000 5.5 38 256 qam 23
24 595000000 5.5 38 256 qam 24
Upstream:
1 39399983 3.75 5120 32 qam 2
2 25799991 3.75 5120 16 qam 4
3 32599983 3.75 5120 32 qam 3
4 46200004 3.75 5120 32 qam 1
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
I don't really have any issues in the logs but the speed has been dismal for the last 2 weeks or so. I was hoping it would sort itself out but seems to be stuck on 5Mbps any time of day/night.
Anyone able to point me in the right direction please? Not really sure why I'm paying £60+ for 5Mbps!!
Frank
  • 2.74K
  • 138
  • 386
jpeg1
Trouble shooter
Re: Slow speed on VIVID 152 (Bracknell Area)
In answer to your first point, to report a fault you call 150 and go through the menu to speak to Support.
The low speed suggests you might be connected by WiFi. If you are measuring with a wired connection then there is certainly something wrong.
Looking at your stats, although they are not complete it looks as if the download is satisfactory but there if something amiss with the upload. The Support staff can check this online.
  • 10
infy101
Thanks, I found a number and called it (I don't have virgin mobile or use my phone line). Once I got this it was pretty easy to raise a fault. I'm hoping they can resolve today/tomorrow.
Frank
