Ofaolain
Just joined
Slow speed after 11pm
Hi can anyone advise why my speeds drop to virtually nothing after 11pm . When I do a speed check I’m lucky to get 2 when I’m on the 350 package
Only had it installed 3 days ago
any hell would be appreciated
  • 18.77K
  • 1.64K
  • 4.09K
Re: Slow speed after 11pm
Would need to check the signal levels if could go to http://192.168.0.1 or if using modem mode http://192.168.100.1 clicking router status top right or bottom of page depending on hub [no need to login - depending on hub] and if could copy/paste the downstream, upstream, network log, don't worry about the formatting we can easily read it.. try and avoid using screen shots.. if could capture before 11pm and after..
also is this via wired/wireless? if wireless can you test speed wired
