ggpb
Message 1 of 5
Slow broadband
I am only getting 40% of my BB speed at best, dropping to 10%. No faults are reported in my area (potters bar) and I have rebooted the system to no avail.
  • 2.41K
  • 116
  • 313
jpeg1
Problem sorter
Message 2 of 5
Re: Slow broadband
Are you measuring that over WiFi or with a wired connection?
Only tests with an ethernet connection are valid
  • 15.2K
  • 653
  • 32
Moderator (Retired) John_G
Moderator (Retired)
Message 3 of 5
Re: Slow broadband
Hi Ggpb,
I've just checked your connection and can see no issues. Your power levels, SNR and area contention all show healthy.
If you're getting poor speeds only over wifi as jpeg1 suggests I'd recommend taking a look at our Wifi Tips page.
ggpb
Message 4 of 5
Re: Slow broadband
Thanks for the check. As a software developer I know how to check the speed and it dropped out completely at one point but it is all OK now.
  • 10.32K
  • 279
  • 588
Forum Team (Retired) Emma_E
Message 5 of 5
Re: Slow broadband
Hi ggpb,
Thanks for getting back in touch. I am glad to see things are looking better for you now.
If you need any help in the future we will be happy to take a look for you.
All the best
Emma
