Slow, and variable speeds
TAtherton
Having issues with variable and at times vary slow speeds on WiFi.
I have had a booster added and although this ‘seemed’ to make a difference initially it has all reverted back to very slow speeds at times.
Near the hub speed test start well over 100 but ends up around 75, elsewhere, including 2 meters from the booster is between 5 and 30mb.
I should be getting up to 200mb.
Here is the info from the router if anyone is able to help?
Thank you in advance.
14620001743.5512064 qam1
22580000043.5512064 qam4
33260000043.5512064 qam3
43939996143.5512064 qam2
1ATDMA0010
3ATDMA0000
4ATDMA0010
13230000001.537256 qam24
2139000000035256 qam1
3147000000035256 qam2
4155000000035256 qam3
5163000000035256 qam4
61710000000.235256 qam5
7179000000035256 qam6
8187000000035256 qam7
9195000000-0.236256 qam8
10203000000-0.735256 qam9
11211000000-0.235256 qam10
12219000000036256 qam11
132270000000.236256 qam12
14235000000036256 qam13
15243000000-0.236256 qam14
16251000000-0.236256 qam15
17259000000036256 qam16
18267000000036256 qam17
192750000000.236256 qam18
202830000000.537256 qam19
212910000000.737256 qam20
22299000000137256 qam21
23307000000137256 qam22
243150000001.237256 qam23
1Locked37.3400
2Locked3565970
3Locked35.548730
4Locked35.518740
5Locked35.518340
6Locked35.519300
7Locked35.79640
8Locked35.712400
9Locked36.62820
10Locked35.73510
11Locked35.74190
12Locked36.31820
13Locked36.31020
14Locked36.3800
15Locked36.31650
16Locked36.3960
17Locked36.6750
18Locked36.6810
19Locked36.6600
20Locked37.6430
21Locked37.3480
22Locked37.3430
23Locked37.6450
24Locked37.3290
04/01/2022 17:00:16noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/2022 17:58:0noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/2022 17:58:0ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/2022 21:34:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/2022 10:43:11noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2021 21:38:58criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2021 23:37:55noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2021 23:37:55ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/12/2021 03:50:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/12/2021 11:37:55noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/12/2021 11:37:55ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2021 21:11:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2021 13:38:2noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2021 13:38:2ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/12/2021 21:09:53criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/12/2021 15:29:1noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/12/2021 15:29:1ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/12/2021 02:09:59criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/12/2021 23:26:8noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/12/2021 23:26:8ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19 REPLIES 19
Hi Karen,
im not sure if you are able to see the historical data for the monitor, I set it up on the 10th and the graphs are showing, however half way drought the day on the 14th they show 100% packet loss. The advice states that it could be that the route is off (it isn’t)or due to firewall settings (I have made no changes) or the ip has changed (I tried to set up another monitor and it said the IP address was already being monitored.  So hadn’t changed)
Can you see the data from the 10th -14th? I have attached some screenshots for the 12th-14th just in case.
I already have a pod which has been shown to increase the speed in the black spot but the issue with variable speeds and drop outs is all over the house. DCA030B7-440D-49BB-93BC-B8DF84F28E79.pngFF0FA2DD-3579-4D9E-A42D-640AE5366F67.png326FF193-2015-4BC3-8ABA-02886D2E589A.png
5CCAFFFF-9CD2-4813-A40B-93F34957A507.jpegBD9B249D-F211-4F0E-87CA-6A170882A4E4.jpegD9569BE2-1FFF-4933-A163-C06DAA09A914.jpeg
Paulina_Z
Hi @TAtherton,
Thank you for coming back to us. I have been able to take another look at your account and run through some checks. I cannot see any issues with your connection on our end at the moment.
All your power levels are within specification and there are no local area issues impacting your services.
Can you tell us if performing a Pin-Hole Reset has helped with this issue? Did the links my colleague provided help at all?
What speeds are you receiving on a wired connection at the moment?
Keep us updated if you can. Thank you,
Paulina_Z
thanks for getting back to me.  The pin reset may have improved things slightly but things are still not stable.  Here is the BQM from yesterday - not great.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/e20146c5b563f99e95d04023538ade8a0e60e443-18-01-2022
please can you advise as I feel that we’re are not getting very far in this forum.
Hi TAtherton,
Thank you for reaching back out to us in our community and welcome back, I have had another look at things our end and cannot see any issues at all, I can see your Router is showing as not been rebooted for 11 Days this indicates that the pin reset you did wasn't done correctly, first check all the internal connections are hand tight then push a pin/ paper clip in the back of the Router where it says reset, push in until you feel it press then hold in for a timed 1 Minute, do not reboot during or after and allow 15 Minutes to settle afterwards?
Paul.
@Paul_DN wrote:
Hi TAtherton,
Paul.
Did you look at the BQM?
Hi. I rest the router as requested almost 2 weeks ago which will be why you are seeing it down 11 days ago?
I set up the BQM. I have attached links etc.
I have also asked if you can see the results. No response
i keep getting asked to do things I have already done.
Is this a stalling tactic?
We are going round in circles.
Hi TAtherton,
Apologies to hear you feel this way. We're not trying to stall, we're collecting all the information you are posting so we can look in to this further for you.
We really appreciate you doing the reboot for us. I'm sorry if I missed this but I can't see a link to your live BQM, only one's for certain dates or pictures. Can you please let us know the live link.
Once we have this, I can raise this up with the area manager as from this end, we're not seeing anything that could be causing these issues so unable to book an engineer as it stands.
Please tag me once you have the live link so I can get the AFM on board right away.
Kath_F
Hi @kath_F
here is the link to the live monitor:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/863aeb1297bc33b68cbb3049992b040622...
Please tell me if you can’t see it use this link as I have a message when trying to post that it’s invalid html and has been removed.
how do I get this to you if the link won’t post?
The WiFi has dropped out completely a couple of times today and remains inconsistent in connections and speed in a similar manner to previous days
I am using relatively new devices and less than 3 meters from the hub or booster
it has impacted on my work today and there is no streaming of media or games being played.
I have resorted to having to tether to my phone and use it’s data for a stable connection
All help gratefully received.
thanks,
Tracy
Ryan_N
I am able to see it don't worry - thank you for that.
What I am going to do is send you a private message so that I can confirm some details with you 🙂
Cheers,
Ryan.
