on 03-11-2021 19:33
Hi all,
I’ve been having issues with my broadband ever since I moved into my flat. About twice a week it will go down, and every night at about 1am there is a short outage.
At all other times it’s very patchy. Websites hang, videos buffer and this is supposed to be a 100mb connection. Right now I’m trying to watch YouTube and it’s juddering every few seconds.
My broadband quality monitor can be seen here:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/d8b4f90c1ea3468a6f06fd8cd3546832750473b1
Any suggestions? Not that good at interpreting these results so would appreciate opinions.
Kevin
on 05-11-2021 09:52
Anyone? It’s playing up again today…
on 05-11-2021 10:17
@Kevie192 wrote:Anyone? It’s playing up again today… <snip>
That BQM is terrible with a lot of packet loss (red fringing at the top). so somthing is badly wrong. Can you check all the connections are finger tight?
Also post the power levels, Pre and PostRS errors, and network log from the Hub for comment.
Check with Area faults on 0800 561 0061 or if you have a VM landline 150 as well.
You can phone the fault in or wait here a day or two for a VM Mod to pick this up.
on 05-11-2021 13:08
05/11/2021 13:03:35 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/11/2021 13:03:26 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/11/2021 13:03:3 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/11/2021 13:02:55 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/11/2021 13:02:51 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/11/2021 13:02:45 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/11/2021 13:02:38 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/11/2021 13:02:18 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/11/2021 13:02:11 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/11/2021 13:01:3 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/11/2021 13:00:37 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/11/2021 13:00:2 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/11/2021 12:59:59 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/11/2021 12:59:41 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/11/2021 12:59:33 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/11/2021 12:58:57 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/11/2021 12:58:39 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/11/2021 12:58:17 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/11/2021 12:58:11 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/11/2021 12:57:54 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 05-11-2021 13:09
1 | 202750000 | -6 | 36 | 256 qam | 9 |
2 | 210750000 | -6 | 35 | 256 qam | 10 |
3 | 218750000 | -6 | 30 | 256 qam | 11 |
4 | 226750000 | -6 | 27 | 256 qam | 12 |
5 | 234750000 | -6 | 37 | 256 qam | 13 |
6 | 242750000 | -6.2 | 37 | 256 qam | 14 |
7 | 250750000 | -6.5 | 37 | 256 qam | 15 |
8 | 258750000 | -6.7 | 37 | 256 qam | 16 |
9 | 266750000 | -5.9 | 37 | 256 qam | 17 |
10 | 274750000 | -5.7 | 37 | 256 qam | 18 |
11 | 282750000 | -5.5 | 37 | 256 qam | 19 |
12 | 290750000 | -5.2 | 37 | 256 qam | 20 |
13 | 298750000 | -5 | 37 | 256 qam | 21 |
14 | 306750000 | -4.9 | 37 | 256 qam | 22 |
15 | 314750000 | -4.9 | 37 | 256 qam | 23 |
16 | 322750000 | -4.7 | 37 | 256 qam | 24 |
17 | 330750000 | -4.7 | 37 | 256 qam | 25 |
18 | 338750000 | -4.5 | 37 | 256 qam | 26 |
19 | 346750000 | -4.5 | 37 | 256 qam | 27 |
20 | 354750000 | -4.9 | 37 | 256 qam | 28 |
21 | 362750000 | -5.7 | 37 | 256 qam | 29 |
22 | 370750000 | -6.2 | 37 | 256 qam | 30 |
23 | 378750000 | -6.5 | 37 | 256 qam | 31 |
24 | 386750000 | -6.5 | 37 | 256 qam | 32 |
on 05-11-2021 13:10
1 | 60300000 | 51 | 5120 | 64 qam | 1 |
2 | 53700000 | 51 | 5120 | 64 qam | 2 |
3 | 39400034 | 51 | 5120 | 64 qam | 4 |
4 | 46199894 | 51 | 5120 | 64 qam | 3 |
on 05-11-2021 13:12
There you go; I thinking that’s what you asked for?
I’ve been in touch with a mod on this already but he was not helpful.
Thank you,
Kevin
on 05-11-2021 14:39
Your power levels need sorted. US is too high and DS is too low. They are both on the limit and need a technician to sort out.
FYI DS levels are -6 to +10 and US levels are 34 to 51.
on 07-11-2021 14:51
Hi @Kevie192,
Thank you for your posts. We're here to help.
I am very sorry to hear you've been having some connection issues recently. Are these ongoing for you today? I've checked the line using the details you provided when signing up to the forums and we're not detecting any issues there currently.
on 07-11-2021 14:54
It seems to be ok today but it won’t be for long, have you looked at my quality monitor? It’s shocking.
