johnnygogo
Slow Speeds and Packet Loss
I'm having trouble with my VIVID100 connection. We have experienced slow speeds for a number of months (max of about 50Mbps - usually around 30Mbps).
Over the past couple of weeks, the connection has stopped working altogether frequently. I usually notice this when the Amazon Echo can't connect to the internet. Rebooting the SuperHub usually resolves, this, but I am having to reboot a couple of times a day.
The call centre tell me there is nothing wrong, but looking at Think Broadband Quality Monitor, I can see there is a high level of packet loss, particularly over the last few weeks. Here are the graphs from the last 3 days:
My Broadband Ping - Virgin Media
  Can anyone help?
  • 68
  • 5
Jay429
Re: Slow Speeds and Packet Loss
Have same issue, Virgin Media customer support are awful.. Not sure how to resolve this just want to cancel and move to BT. Fed up of all this Smiley Sad
Take one look at Virgin medias trust pilot review says it all.
jmatt
Just joined
Bandwidth has been 70 - 100 mb/s up until 2 days ago.
Last two days can get no better than 2 mb/s.
VM say everything checks out fine.
There are no reasonable ways to contact VirginMedia.
Even to leave!
  • 5.38K
  • 598
  • 845
Superstar
Try calling “Retentions” on 150 or 0345 454 1111 - options 1-1-4-5 "Thinking of leaving" then “technical issues” – (They are open Monday – Friday, 8am - 8pm and on Saturday from 8am - 6pm. – [08.01 is best!]) you have a better chance of getting a UK call centre (it could still be a 30’+ wait though) who will be more understanding and helpful. Tell them you are thinking of leaving for Sky/BT because of these problems - and they will try and sort it for you (as it’s their job to keep customers) or give you best info on the problem - or help you leave.
  • 10.32K
  • 278
  • 588
Forum Team (Retired) Emma_E
Hi johnnygogo,
Thanks for getting in touch. I am sorry to see you have had trouble with your connection.
I have taken a look and things seem to be ok from this side. It may help to try the following so we can rule some things out:
Pop the hub into Modem Mode with the computer in Safe Mode with Networking at different times of the day.
Try on separate devices.
Check Ethernet cable. Make sure it is new / up to date. (Cat 5e or above).
Make sure device is capable of agreed speed.
Check wireless card slide.
Take care.
 Emma
johnnygogo
Hi Emma_E,
I've tried all those things on the advice of the call centre, and the fact that the issue is on both wireless and wired, and the Quality Monitor is detecting packet loss would suggest that this isn't an issue with one of my devices or cables.
Looking at the network log on my router, i can see the following:
Time
Priority
Description
2019-01-11 09:10:28.00
critical
No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
Warning!
RCS Partial Service;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2019-01-11 09:10:30.00
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
Warning!
2019-01-11 09:10:31.00
critical
These times coincide when when I had connection issues this morning. Could this help identify the problem?
Also, below is the information from the router status screen:
Cable Modem Status
Item
Status
Comments
298750000
Locked
Ranged Upstream Channel (Hz)
25800000
Locked
Provisioning State
Online
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
298750000
3.7
38
256 qam
21
2
322750000
2.9
38
256 qam
24
3
314750000
3
38
256 qam
23
4
306750000
3.4
38
256 qam
22
5
290750000
3.2
38
256 qam
20
6
282750000
3.2
38
256 qam
19
7
274750000
3.2
38
256 qam
18
8
266750000
3
38
256 qam
17
9
258750000
3
38
256 qam
16
10
250750000
4
38
256 qam
15
11
242750000
4.9
38
256 qam
14
12
234750000
5
38
256 qam
13
13
226750000
4.9
38
256 qam
12
14
218750000
5
38
256 qam
11
15
210750000
5.4
38
256 qam
10
16
202750000
5.9
38
256 qam
9
17
194750000
6.5
40
256 qam
8
18
186750000
6.9
38
256 qam
7
19
178750000
6.5
38
256 qam
6
20
170750000
6.8
40
256 qam
5
21
162750000
6.6
40
256 qam
4
22
154750000
6.8
40
256 qam
3
23
146750000
7.5
38
256 qam
2
24
138750000
7.4
40
256 qam
1
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
25800000
45.8
5120
64 qam
8
2
46200000
46.3
5120
64 qam
5
3
32600000
46
5120
64 qam
7
4
39400000
46
5120
64 qam
6
