Cookie-101
  • 14
Message 1 of 18
Slow Connection Speed
I have recently signed up to VM as I have moved to a new area.  I am paying for the M350 package but I am experiencing speeds of only around 40Mbps.  If I restart the router to factory settings it works for a short time at the rated speed but then drops off back down to the slow speeds again. Looking through the router status page I seem to have quite a lot of Post RS Errors on some channels and the SNR on a couple of them (CH11 and CH12) seems to be a fair bit lower than the rest.  I have had an engineer out and all he did was switch out my Hub3 for a Hub4, and because the speed was where it should have been after the new hub was installed he left thinking the problem was fixed, however shortly after it returned to the slow speeds.
Cookie-101
  • 14
Message 2 of 18
Re: Slow Connection Speed
3.0 Downstream channels
253310000002.40000238.605377QAM25625
11390000006.40000238.605377QAM2561
21470000004.90000237.636276QAM2562
31550000003.79999937.355988QAM2563
41630000003.79999937.636276QAM2564
51710000003.50000038.983261QAM2565
61790000002.70000138.605377QAM2566
71870000002.70000138.983261QAM2567
81950000001.79999938.983261QAM2568
92030000001.00000038.983261QAM2569
102110000000.70000138.605377QAM25610
11219000000-1.59999824.133797QAM25611
12227000000-2.00000031.403784QAM25612
13235000000-2.00000036.386890QAM25613
14243000000-1.50000038.605377QAM25614
15251000000-1.09999838.605377QAM25615
162590000000.00000038.983261QAM25616
17267000000-0.59999838.605377QAM25617
18275000000-0.09999838.605377QAM25618
19283000000-0.70000138.605377QAM25619
202910000000.29999938.983261QAM25620
21299000000-0.40000238.605377QAM25621
223070000001.09999838.983261QAM25622
233150000001.90000238.605377QAM25623
243230000000.59999838.605377QAM25624
263390000001.29999938.983261QAM25626
273470000001.29999938.983261QAM25627
283550000000.40000238.605377QAM25628
29363000000-0.90000238.605377QAM25629
303710000000.40000238.605377QAM25630
313790000000.09999838.605377QAM25631
25Locked000
1Locked39836409298678379
2Locked2484895713345162237
3Locked395761803374451109
4Locked3917113119569420
5Locked39218872120
6Locked3969633400
7Locked39783804670
8Locked2981427670
9Locked29489871100
10Locked1593582033
11Locked243823507531431804920
12Locked2944932441478321462531
13Locked292623419571
14Locked29501016145
15Locked2924577000
16Locked3062648600
17Locked3050455900
18Locked3025657900
19Locked3032192300
20Locked3046986700
21Locked3035252200
22Locked3044743300
23Locked2731183300
24Locked6993037600
26Locked6980264300
27Locked6992980600
28Locked6975367500
29Locked6991692700
30Locked6987081600
31Locked83555209000
3.1 Downstream channelsChannel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
159804K1560QAM4096392
3.1 Downstream channelsChannel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
159Locked -1.11596291970
Cookie-101
  • 14
Message 3 of 18
3.0 Upstream channels
13260000050.5205995120 KSym/sec64QAM3
22580000048.7705995120 KSym/sec64QAM4
33940000048.7705995120 KSym/sec64QAM2
44620000049.2705995120 KSym/sec64QAM1
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
Cookie-101
  • 14
Message 4 of 18
Sat 14/11/2020 10:44:266CM-STATUS message sent. Event Type Code: 5; Chan ID: 11; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 10:44:445Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 10:44:446CM-STATUS message sent. Event Type Code: 2; Chan ID: 12; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:00:265MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:00:345Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:00:426CM-STATUS message sent. Event Type Code: 5; Chan ID: 12; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:00:445Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:00:566CM-STATUS message sent. Event Type Code: 5; Chan ID: 12; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:07:285Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:07:326CM-STATUS message sent. Event Type Code: 5; Chan ID: 12; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:13:125Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:13:216CM-STATUS message sent. Event Type Code: 5; Chan ID: 11; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:13:545Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:13:586CM-STATUS message sent. Event Type Code: 5; Chan ID: 11; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:19:055Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:19:166CM-STATUS message sent. Event Type Code: 4; Chan ID: 12; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:19:425Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:19:446CM-STATUS message sent. Event Type Code: 5; Chan ID: 12; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:20:305Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:20:486CM-STATUS message sent. Event Type Code: 4; Chan ID: 12; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:21:025Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:21:216CM-STATUS message sent. Event Type Code: 5; Chan ID: 11; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:22:165Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:22:266CM-STATUS message sent. Event Type Code: 5; Chan ID: 12; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:24:195Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:24:426CM-STATUS message sent. Event Type Code: 4; Chan ID: 12; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:24:565Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:25:026CM-STATUS message sent. Event Type Code: 1; Chan ID: 11; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:25:365Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:25:496CM-STATUS message sent. Event Type Code: 5; Chan ID: 12; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:26:205Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:26:426CM-STATUS message sent. Event Type Code: 5; Chan ID: 12; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:30:065Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:30:206CM-STATUS message sent. Event Type Code: 5; Chan ID: 12; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:35:285Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:35:356CM-STATUS message sent. Event Type Code: 5; Chan ID: 12; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:44:155Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:44:236CM-STATUS message sent. Event Type Code: 4; Chan ID: 12; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:53:105Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 11:53:156CM-STATUS message sent. Event Type Code: 4; Chan ID: 12; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Buffer6
  • 11.1K
  • 93
  • 628
Hero
Message 5 of 18
Your voltage levels are all over the place, with post errors and there seems to be congestion at times in your BQM
Check your service status at the top right of page, if it reports OK
then I think you will need an engineers visit, you can try to get through on landline to VM
Or wait until one of the Forum staff picks up your thread.
Cookie-101
  • 14
Message 6 of 18
The service status reports that there are no known issues.
Cookie-101
  • 14
Message 7 of 18
Still having this issue, paying for M350 package but regularly seeing download speeds of only 45Mbps.  Can't get through to speak to anyone on the phone.
I have noticed though that the problem seems to be more apparent in the wet weather, which in West Yorkshire seems to be most of the time.
Cookie-101
  • 14
Message 8 of 18
Starting to log my speeds, as said before should be 350Mbps down
https://www.speedtest.net/result/10872376429
Cookie-101
  • 14
Message 9 of 18
Todays speed:
32.36Mbps Down - 31.53Mbps Up
https://www.speedtest.net/result/10878516308
These are not the speeds I am paying for.  What do I have to do to get this issue fixed?
-tony-
  • 16.9K
  • 1.32K
  • 3.99K
Message 10 of 18
may have missed it but how are you testing - wired or wifi
____________________
Tony
