  • 16
Donmega
Slooow Speeds down by 70% Help
Intermittent connections and slow speeds -  Can someone help with my slow speeds, please?
  • 6.73K
  • 704
  • 1.03K
Legend
Re: Slooow Speeds down by 70% Help
Not without a lot more information about your equipment and package and the specific details of the problem
  • 18.86K
  • 1.65K
  • 4.12K
to add what jbrennand said, would need to know this wired/wireless?, if its wireless can you test the speed wired..
Would need to check the signal levels if could go to http://192.168.0.1 or if using modem mode http://192.168.100.1 clicking router status top right or bottom of page depending on hub [no need to login - depending on hub] and if could copy/paste the downstream, upstream, network log, don't worry about the formatting we can easily read it.. try and avoid using screen shots..
  • 10.32K
  • 279
  • 588
Forum Team (Retired) Emma_E
Hi Donmega,
Welcome to the forums, I am sorry to see you have been having trouble with your connection.
I have taken a look and your downstream modem SNR too low. I would like to get an engineer out to take a look at this for you.
I will pop you a Pm to get this arranged. Keep an eye out for the Purple Envelope top right hand corner.
Speak to you soon.
Emma
