on 21-10-2021 17:04
Hi All
I just installed Hub 4 for the 1 gig service, i was m500 and got 550 download 99% of the time...
When i first turned on the hub 4 and did a speed test i was getting 945 download
i then get a text message from virgin to say they sent a signal and everything is ready, i then do another speed test and i can barley get over 300 download... can you see from below data if their is an issue...
All test carried out ethernet cable into Virgin Media Router...
on 21-10-2021 18:19
These are the speeds i was getting on M500
Now i get these speeds surely something is not right here.
on 25-10-2021 12:37
Hello cor3ys
Thank you so much for such a detailed post
Sorry though this is happening, Clearly something isn't right
I am more than happy to take a look at this for you
I will need to send you a private message to pass security
If you can check the purple envelope top right of your screen that would be great
Gareth_
