mrbill1234
  • 16
Message 1 of 11
Seeing intermittent packet loss - appears to be on Virgin internal network
Seems to have started in the past few days.
Between 10-20% packet loss and intermittent high latency pinging 8.8.8.8
Can someone check?
Area reference 22
WD3
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 2 of 11
Re: Seeing intermittent packet loss - appears to be on Virgin internal network
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Can you set up a Broadband Quality Monitor (BQM) at thinkbroadband.com - this will give you an insight into what is happening with the signal at the other side of the Hub, it will take a few hours to get any kind of trend showing although you can post the link straight away.
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
mrbill1234
  • 16
Message 3 of 11
After i posted this message, it was quite a bit better last night - but now this morning, lots of loss again.
BQM ( have just enabled ICMP for the purpose of this test).
https://www.thinkbroadband.com/broadband/monitoring/quality/share/72c89719fa506a0669201e68b44f4b0405...
First TimeLast TimePriorityError NumberDescription
 15/07/2020 13:09:48  15/07/2020 13:09:48  Critical (3)  2436694080  TOD resynchronisation failure
 15/07/2020 13:09:48  15/07/2020 13:09:48  Critical (3)  2436694077  TOD server unavailable
 15/07/2020 15:38:30  15/07/2020 15:38:30  Error (4)  68000403  ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
 15/07/2020 15:58:28  15/07/2020 15:58:28  Critical (3)  2436694078  TOD established
 13/07/2020 07:53:21  13/07/2020 07:53:21  Critical (3)  82000500  Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
 12/07/2020 11:17:56  12/07/2020 11:17:56  Critical (3)  82000400  Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
 12/07/2020 11:17:15  12/07/2020 11:17:15  Critical (3)  82000200  No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
mrbill1234
  • 16
Message 4 of 11
I rebooted the super hub again - seems better, but I tried that before.  Let's see how long it lasts.
I'm in modem mode if it makes any difference.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 5 of 11
Your >> BQM << is a mess.
You need to contact VM.
You can contact VM to report your problem using ...
Text service on 07533051809
150 from Virgin landline.
0345 454 1111 from any other UK  phone.
The best time to call is weekdays 08:00 to get a UK agent, anything after 10:00 you must realise that you are quite likely to get through to an offshore agent that doesn't speak English as a first language.
Or you can wait on here for one of the VM Staff to pick up the thread but this may take a few days.
mrbill1234
  • 16
Message 6 of 11
Can you elaborate a bit on this?
What should I say when I call VM?  Bloke on the community forums said my BQM is a mess?  🙂
You can see where I rebooted at about 2.30 but then latency goes for a loop - not that it was ever good.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 7 of 11
  • 15.42K
  • 662
  • 1.51K
Message 8 of 11
You have a super hub 1 it will be better if its in modem mode with your own wireless router with 1Gb ports.
If your in modem mode what own router do you have or have you just connected a PC to the hub?
mrbill1234
  • 16
Message 9 of 11
I thought I had a superhub 2 - diags say
Super Hub VMDG480
I will give VM a call and tell them about poor performance, though if you could elaborate about what you see in the Diags, that may help.
thanks
mrbill1234
  • 16
Message 10 of 11
What should a good Virgin Media BQM look like?
