30-01-2023 16:52 - edited 30-01-2023 17:05
Hemel Hempstead(HP2)
Looks like the connection went down originally at around 12:30PM(ish) before coming back at just before 3PM.
Online fault checker is showing nothing wrong (currently).
Just posting so this can get potentially flagged up/noted.
Live Graph:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/1700d27c199ce3ea214d66ce063ff9f395507b3e
Todays snapshot:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/bd4c5b3ba711cd6c987a5b0314b71dd8761d746d-30-01-2023
Stats will be posted next:
as you can see: Only 1 upstream channel
1 | 30100657 | 57 | 5120 | 32 qam | 4 |
1 | ATDMA | 0 | 0 | 4 | 0 |
1 | 563000000 | -9 | 37 | 256 qam | 20 |
2 | 539000000 | -8.4 | 37 | 256 qam | 17 |
3 | 547000000 | -8.7 | 37 | 256 qam | 18 |
4 | 555000000 | -8.7 | 37 | 256 qam | 19 |
5 | 571000000 | -9.2 | 37 | 256 qam | 21 |
6 | 579000000 | -9.5 | 37 | 256 qam | 22 |
7 | 587000000 | -9.5 | 37 | 256 qam | 23 |
8 | 595000000 | -9.4 | 37 | 256 qam | 24 |
9 | 603000000 | -9.4 | 37 | 256 qam | 25 |
10 | 611000000 | -9.5 | 37 | 256 qam | 26 |
11 | 619000000 | -9.7 | 37 | 256 qam | 27 |
12 | 627000000 | -9.7 | 37 | 256 qam | 28 |
13 | 635000000 | -9.5 | 37 | 256 qam | 29 |
14 | 643000000 | -9.2 | 37 | 256 qam | 30 |
15 | 651000000 | -9 | 37 | 256 qam | 31 |
16 | 659000000 | -8.7 | 37 | 256 qam | 32 |
17 | 667000000 | -8.9 | 37 | 256 qam | 33 |
18 | 675000000 | -8.9 | 37 | 256 qam | 34 |
19 | 683000000 | -9 | 37 | 256 qam | 35 |
20 | 691000000 | -8.9 | 37 | 256 qam | 36 |
21 | 699000000 | -8.9 | 37 | 256 qam | 37 |
22 | 707000000 | -8.7 | 37 | 256 qam | 38 |
23 | 715000000 | -8.7 | 37 | 256 qam | 39 |
24 | 723000000 | -8.9 | 37 | 256 qam | 40 |
1 | Locked | 37.3 | 11 | 0 |
2 | Locked | 37.6 | 9 | 0 |
3 | Locked | 37.6 | 16 | 0 |
4 | Locked | 37.6 | 10 | 0 |
5 | Locked | 37.3 | 19 | 0 |
6 | Locked | 37.3 | 25 | 0 |
7 | Locked | 37.3 | 21 | 0 |
8 | Locked | 37.6 | 18 | 0 |
9 | Locked | 37.6 | 23 | 0 |
10 | Locked | 37.6 | 26 | 0 |
11 | Locked | 37.6 | 29 | 0 |
12 | Locked | 37.6 | 34 | 0 |
13 | Locked | 37.3 | 40 | 0 |
14 | Locked | 37.3 | 41 | 0 |
15 | Locked | 37.6 | 22 | 0 |
16 | Locked | 37.3 | 21 | 0 |
17 | Locked | 37.3 | 20 | 0 |
18 | Locked | 37.3 | 20 | 0 |
19 | Locked | 37.3 | 21 | 0 |
20 | Locked | 37.6 | 21 | 0 |
21 | Locked | 37.6 | 15 | 0 |
22 | Locked | 37.6 | 15 | 0 |
23 | Locked | 37.6 | 17 | 0 |
24 | Locked | 37.6 | 11 | 0 |
Gonna have to remove the 6DB attenuator to bring powers back into range at some point when I have the chance, too.
Kind of lucky I'm only using this as a backup connection/for family members now.. lol
17-02-2023 16:55 - edited 17-02-2023 17:25
@unisoft wrote:If QAM isn't 64 on your upstream channels, it's wrong. Its being negotiated to a lesser level which means less bandwidth on each channel.
And this in turn means your spending more bandwidth time causing less bandwidth time the upstream could knock out like if water you have 5 upstream each 1L for QAM64 you can pour 3L within 1000ms no problem but if you drop to QAM16 say 500ml then you can only pour 2.5L within 1000ms
your BQM looks good now from 10:30am maybe VM unlock the modulation more so you don't stay at 64QAM or your connection got better
on 19-02-2023 00:57
FYI: the modulation order / QAM changes on the upstream are automatic and are triggered by upstream SNR, alongside corrected and uncorrected FEC superframes counts at the CMTS.
See for example https://www.cisco.com/c/en/us/td/docs/cable/cmts/config_guide/b_cmts_ds_us_features/b_cmts_ds_us_fea...
For how it was way back when. It's changed since. VM don't have some timing set. More likely the noise floor improved.
on 21-02-2023 09:48
Hi Icantcrabhere,
Thanks for coming back to us with another link for your BMQ graph, although it's not perfect I have seen much worse connections than what is showing in your graph, so I am not too concerned at the moment.
Could you describe exactly what is occurring over your WIFI/Wired connections when an issue arises please?
I have checked on our side and I haven't been able to locate any issues at present.
Megan_L
on 21-02-2023 16:42
Hi Megan,
To show as an example of what happens when it's bad:
This is from the 16th of this month:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/2676b89afb5437e8e3ddb7063e4325d1aa290875-16-02-2023
this is from the 17th:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/3d99c271e321163cb29be485856be1b7eb...
QAM dropping from 64 on the upstream is not normal.
So other than minimum latency being more jittery when the modulation is incorrect, packet loss also occurs.
Other than that? - I'd like a clean/working service that doesn't have major modulation issues (again: previous posts over the last few years documenting this)
I don't expect a perfect service, nor am I hoping for a perfect looking graph,
I'm wanting consistency and a bit more than what i've received the last few years.
Cheers for your help so far.
on 21-02-2023 17:52
on 21-02-2023 18:57
All in spec currently, other than the low frequency channel. (23600033) - all 64QAM other than this one (which is sitting at 32)
I realize that that channel is super sensitive to noise and some dips however.
Again,
I don't expect perfection, just a decent level of consistency.
Cheers!
on 24-02-2023 09:27
Hi there @Icantcrabhere
Thank you for updating us and we are so sorry that the service has been inconsistent for you. Can I ask how things have been since your last post?
Thank you
24-02-2023 11:16 - edited 24-02-2023 11:19
@Icantcrabhere wrote:All in spec currently, other than the low frequency channel. (23600033) - all 64QAM other than this one (which is sitting at 32)
Again,
Cheers!
Talk about banging your head against the wall. Anything less than QAM64 on the upstream is incorrect. People moved from QAM16 to QAM64 to allow for more bandwidth and less congestion allied to more bonded upstreams added. All upstreams should be on QAM64 (allowing for trial areas that may be higher).
You've hit the "we don't care about HFC anymore unless something detrimental to your connection, as we are going to fibre/XGS-PON". Basically, doing as little as they can get away with for existing HFC because it's money on legacy kit.... That's how I interpret VM's response initially.
on 24-02-2023 18:36
Hi @Ashleigh_C,
Upstream QAM is currently in spec,
for how long? I don't know - and i'm not sure how to further assure this doesn't keep happening.
@unisoft:
Yeah, as I've always said: I should be owed a bunch of money for the amount of painkillers I've to take with this ISP. - my head is well and truly dented 🙂
It really does feel like they've stopped caring, countless issues for years in regards to my upstream.
I'll tell the staff members here each time I post "Check my history" - it's truly wild, eh?
We've had a bunch of new VM cabinets fitted fairly close to me now: well, a street(ish) over being the closest.
so not sure when/what's going to happen.
Although I'm basically using this connection as a backup / family and friends, It's still truly grating
on 27-02-2023 16:15
We can see you have spoken to the team since posting, we can also see the hub is in modem mode which limits the checks we can run. If you would like further assistance please let us know when the hub is out of modem mode so we can look.
Rob
