daudnadeem
  • 5
Message 1 of 8
SLOW upload/dl speed?
I am on Fibre Plus which is approx 108mbps. The average upload speed I would expect is 10mbps. And it is 10mbps from 11pm > 5am. Outside of these hours it's an average of 1mbps, and can go as low as 0.2 mbps. This is quite an issue since I am working from home. I paid for a decent package, so I could do my work "software programming" as well as chat to team on "Microsoft Teams" (Video calls require upload speeds) and am getting terrible upload speed. Download speeds are the same, 100mbps after dark, and 20 - 50mbps in the day time.
This is some form of fraud, is it not? I paid for a better service than this.
P.s I am on a wired connection, I am the only person in my household, am checking speeds on mac/iphone (wired/wireless) and my router is brand new. No technical issues, just a bad service provided.
conman33158
  • 799
  • 76
  • 106
Superfast
Message 2 of 8
Re: SLOW upload/dl speed?
Can you please upload your router stats
Type 192.168.0.1 or (192.168.100.1 if you have your Hub in Modem mode) into your address bar at the top of your browser
For Hubs 2 & 3 - DO NOT LOG IN, just click “Check Router Status”
For Hub 4 - When the page appears LOG IN then click on:
Advanced Settings > Tools > Network Status.
Please copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs, if you get a yellow warning just click the Post button again. You can use more than one post for each item if needed.
If you get a warning when you hit “Post” just hit “Post” again and it should work ok!
Please do not use screenshots
Also can you please set up a Broadband Quality Monitor (BQM) at thinkbroadband.com.
Post a 'Live Link' to your BQM on here asap.
Under your graph you just created Click (Share Live Graph) then click generate.
Copy the text in the Direct Link box and paste it on here
daudnadeem
  • 5
Message 3 of 8
Link to BQM:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/72f081313e0c11439ede07f120fd209d84...
 Status
139000000
Locked
Ranged Upstream Channel (Hz)
60299903
Locked
Provisioning State
Online
Downstream
11390000005.138256 qam1
21470000004.638256 qam2
31550000004.538256 qam3
41630000004.538256 qam4
5171000000438256 qam5
61790000003.938256 qam6
71870000003.738256 qam7
81950000003.538256 qam8
92030000003.438256 qam9
102110000003.538256 qam10
112190000003.537256 qam11
122270000003.938256 qam12
13235000000440256 qam13
142430000004.139256 qam14
152510000004.540256 qam15
162590000004.838256 qam16
17267000000540256 qam17
18275000000540256 qam18
19283000000540256 qam19
20291000000538256 qam20
212990000005.438256 qam21
22307000000540256 qam22
233150000005.140256 qam23
243230000005.340256 qam24
1Locked38.9900
2Locked38.6970
3Locked38.915113
4Locked38.9950
5Locked38.61130
6Locked38.9920
7Locked38.61000
8Locked38.6880
9Locked38.6840
10Locked38.6910
11Locked37.3600
12Locked38.6290
13Locked40.3180
14Locked39.3240
15Locked40.3210
16Locked38.9180
17Locked40.3150
18Locked40.9360
19Locked40.9170
20Locked38.9160
21Locked38.9440
22Locked40.9220
23Locked40.3230
24Locked40.339
0
daudnadeem
  • 5
Message 4 of 8
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
16029990346512064 qam1
25370000046.3512064 qam2
34620000046.3512064 qam3
43940000046.8512064 qam4
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1ATDMA0010
3ATDMA0000
4ATDMA000
0
Configuration
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt057-b.cm
SFID71498
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID71497
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling Type
BestEffort
Network LogTime Priority Description
29/01/2021 09:13:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/01/2021 17:35:1noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 17:34:50criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 15:05:18ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2021 21:55:44criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2021 19:03:1noticeSW download Successful - Via Config file
24/01/2021 19:00:45noticeSW Download INIT - Via Config file
21/01/2021 17:05:23Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2021 16:33:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2021 14:41:24noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2021 10:41:36Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/01/2021 22:05:11ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/01/2021 21:40:57criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/01/2021 21:13:9noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/01/2021 21:13:4Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/01/2021 21:07:18noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/01/2021 21:06:28ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/01/2021 20:37:0noticeSW download Successful - Via Config file
19/01/2021 20:35:4noticeSW Download INIT - Via Config file
01/01/1970 00:02:5critical16 consecutive T3 timeouts while trying to range on upstream channel 4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
conman33158
  • 799
  • 76
  • 106
Superfast
Message 5 of 8
Your line stats look fine with a few errors in your network log but your BQM so far doesn't look good, could be a sign of over utilisation. We will let it run for a while typically overnight to get a better picture.
daudnadeem
  • 5
Message 6 of 8
Okay thank you. Hopefully will know more tomorrow.
daudnadeem
  • 5
Message 7 of 8
Any update?
conman33158
  • 799
  • 76
  • 106
Superfast
Message 8 of 8
@daudnadeem wrote:
Any update?
Not good news I'm afraid 😞 Your line shows over utilisation. You can ring Virgin about this with maybe a fix date for the future but to be honest I wouldn’t hold my breath as they have a tendency to apply fix dates only to keep moving them forward and then ending up with nothing being done for months/years.
