draki
  • 44
Recent work Area 21 - stability, speed inconsistency issues
Hi - I'm on M500 fibre and am getting wildly different speeds - average is around 200MBs, Range 60-500 (I'm monitoring it hourly at the moment). End user experience is OK, but internet often feels 'laggy' and occasionally slow.
Before the recent work the connection was pretty stable at >500
Posting here in hope of getting some online support from Virgin Media
Adding info requested in similar posts - LMK if more is needed
BQM:
02/10/2020 06:19:4 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/10/2020 01:48:26 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/09/2020 19:46:59 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/09/2020 04:55:23 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/09/2020 05:41:53 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 19:51:12 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 10:37:17 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 10:00:35 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/09/2020 12:12:55 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/09/2020 10:20:3 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2020 15:24:47 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2020 09:49:21 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/09/2020 18:04:17 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/09/2020 07:11:52 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/09/2020 02:19:17 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/09/2020 00:03:0 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/09/2020 00:03:0 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/09/2020 00:02:59 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/09/2020 23:59:34 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/09/2020 23:59:33 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Downstream
1 298750000 3 38 256 qam 21
2 266750000 2.2 38 256 qam 17
3 274750000 2.2 38 256 qam 18
4 282750000 2.5 38 256 qam 19
5 290750000 2.7 38 256 qam 20
6 306750000 3.2 38 256 qam 22
7 314750000 3.2 38 256 qam 23
8 322750000 3.2 38 256 qam 24
9 330750000 3.5 38 256 qam 25
10 370750000 3.5 38 256 qam 26
11 378750000 3.9 38 256 qam 27
12 386750000 4 38 256 qam 28
13 394750000 4.1 38 256 qam 29
14 402750000 4 38 256 qam 30
15 410750000 4.3 38 256 qam 31
16 418750000 4.1 38 256 qam 32
17 426750000 4.4 38 256 qam 33
18 434750000 4.1 38 256 qam 34
19 442750000 4.3 38 256 qam 35
20 450750000 4.3 38 256 qam 36
21 458750000 4.4 38 256 qam 37
22 466750000 4 38 256 qam 38
23 474750000 4.1 38 256 qam 39
24 482750000 4.5 38 256 qam 40
1 Locked 38.6 8671 3530
2 Locked 38.6 13414 2293
3 Locked 38.9 13227 3571
4 Locked 38.9 12141 2618
5 Locked 38.6 7348 1559
6 Locked 38.9 6176 2731
7 Locked 38.9 5182 2300
8 Locked 38.9 6739 3376
9 Locked 38.9 4348 2445
10 Locked 38.6 4673 3669
11 Locked 38.9 3907 2577
12 Locked 38.9 7497 5117
13 Locked 38.6 4468 4557
14 Locked 38.9 5604 4646
15 Locked 38.6 3931 7575
16 Locked 38.9 3460 4494
17 Locked 38.6 5086 5389
18 Locked 38.9 2542 391
19 Locked 38.6 2827 5398
20 Locked 38.9 4152 5899
21 Locked 38.6 2925 4806
22 Locked 38.6 1863 2605
23 Locked 38.6 1784 2210
24 Locked 38.6 612 2342
Upstream
1 39400000 3.5 5120 64 qam 4
2 46200013 3.575 5120 64 qam 3
3 32600000 3.475 5120 64 qam 5
4 25800000 3.475 5120 64 qam 6
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
Tags (4)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Recent work Area 21 - stability, speed inconsistency issues
Just for information, the area codes are administrative areas not geographical.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
In the URL box paste the link you copied and in the ‘text to display’ box write My BQM then click OK - you can post the link straight away
draki
  • 44
Thanks - no, no issues - and this has been going on for a week or more...
Isn't the BQM image above enough or do you need the live graph specifically?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
The BQM in Post # 1 is only any good up until 06:00ish.
You can post historical ones but they need to have a date on them but 'Live' graphs are better.
draki
  • 44
Here you go - BQM
Corey_C
  • 3.94K
  • 214
  • 328
Hi draki,
Thanks for your post and for reaching out to the community forums. Sorry to hear that you have been having connection issues, I'll send you a PM shortly to get your account details.
Cheers,
Corey C
