02-05-2021 16:27 - edited 02-05-2021 16:31
Hi there,
I've purchased Gig1 and the HUB 4 kit arrived on 30/04/2021. Since then my speeds have been extremely slow.
All these devices are consistently slow so I think it's reasonable to believe that it is not device related or a problem with cables.
I've posted a few Samknows screens below. In some cases it shows 300-400 Mbps to the Hub although I have never had this speed on any of my devices so I'm not sure how to interpret that. Speeds are usually around 30-40Mbps. Sometimes speedtest bursts to 160 Mbps for a few seconds but no where near the 400Mbps seen on the hub4 according to samknows.
Screens and Network status below if it helps. Any ideas will be welcome.
on 09-05-2021 13:34
That's definitely not good at all.
I remember having connection and latency issues back in 2011-2012 with VM which is why I switched to a different provider. You would think things would improve after 10 years...
Unfortunately the 2nd best line is only 60-70 Mbps.
on 09-05-2021 13:46
I understand.
The best I can get is 8-16mb.
However I may still get one and use it just for gaming if this keeps up.
