Travis7
  • 5
Message 1 of 9
Problem in Virgin servers?
Few days now the speed is very slow most of the time. When I trace it here what appears:
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 9
Re: Problem in Virgin servers?
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 9
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 9
Can you please
DJ_Shadow1966
  • 7.2K
  • 1.37K
  • 2.06K
Message 5 of 9
Hello
The reason you have some timeouts when doing is tracert is because that hop is set to not reply to a request hence the timeout it is quite normal, the tracert has completed as it shows the end IP address. This will not affect your speed.
Regards Mike
Travis7
  • 5
Message 6 of 9
BQM looks fine. There are just few yellow spikes.
Here is the router status:
12270000003.438256 qam12
22190000003.538256 qam11
32350000003.238256 qam13
4243000000338256 qam14
5251000000338256 qam15
62590000002.738256 qam16
72670000002.738256 qam17
82750000002.538256 qam18
92830000002.538256 qam19
102910000002.538256 qam20
112990000002.938256 qam21
123070000002.738256 qam22
133150000002.938256 qam23
143230000003.238256 qam24
153310000003.238256 qam25
163390000003.538256 qam26
173470000003.538256 qam27
183550000003.438256 qam28
193630000003.238256 qam29
20371000000338256 qam30
21379000000338256 qam31
223870000002.938256 qam32
23395000000338256 qam33
24403000000338256 qam34
1Locked38.936124
2Locked38.64030
3Locked38.94343
4Locked38.64855
5Locked38.64358
6Locked38.93737
7Locked38.64141
8Locked38.64333
9Locked38.64529
10Locked38.647107
11Locked38.95030
12Locked38.94834
13Locked38.64948
14Locked38.64745
15Locked38.94050
16Locked38.93628
17Locked38.95239
18Locked38.942115
19Locked38.94464
20Locked38.63237
21Locked38.96762
22Locked38.93949
23Locked38.63834
24Locked38.93359f
Travis7
  • 5
Message 7 of 9
13940000044.5512064 qam6
22580000044512064 qam8
33260000044512064 qam7
44620000044.5512064 qam5
1ATDMA0030
2ATDMA0010
3ATDMA0040
4ATDMA0020
Travis7
  • 5
Message 8 of 9
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
rkldJKDHSUBsgvca69834ncxv9873
SFID18916
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID12472
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
Travis7
  • 5
Message 9 of 9
25/11/2020 13:23:6noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/11/2020 12:09:10Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/11/2020 11:28:41Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/11/2020 04:15:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/11/2020 01:38:34noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/11/2020 01:38:34ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/11/2020 05:11:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 22:55:48noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 22:55:48ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 12:38:6criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 10:55:47noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 10:55:47ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 07:34:38noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 07:34:38ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 08:46:56criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 01:17:1noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 01:17:1ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 22:58:21Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/11/2020 23:42:56criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/11/2020 13:17:1noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
