Glenn2
  • 52
  • 5
Message 1 of 16
Poor speed - SNR?
I'm on 100Mbps and until recently always got 110/10 speeds.
Lately I am lucky to get 50, and for the last two days I can't even do voice-only meetings on Teams it's that bad.
The router snr stats look bad - is that the reason?
1 298750000 0.9 34 256 qam 21
2 138750000 0.7 33 256 qam 1
3 146750000 -0.4 33 256 qam 2
4 154750000 0.9 33 256 qam 3
5 162750000 1.2 34 256 qam 4
6 170750000 1.5 34 256 qam 5
7 178750000 1.5 34 256 qam 6
8 186750000 1.5 34 256 qam 7
9 194750000 1.4 34 256 qam 8
10 202750000 1.2 35 256 qam 9
11 210750000 1.2 35 256 qam 10
12 218750000 1 35 256 qam 11
13 226750000 0.9 35 256 qam 12
14 234750000 0.7 34 256 qam 13
15 242750000 0.7 35 256 qam 14
16 250750000 0.9 34 256 qam 15
17 258750000 0.5 35 256 qam 16
18 266750000 0.5 35 256 qam 17
19 274750000 0.2 35 256 qam 18
20 282750000 0.2 34 256 qam 19
21 290750000 0.5 35 256 qam 20
22 306750000 1.4 35 256 qam 22
23 314750000 1.5 35 256 qam 23
24 322750000 1.5 35 256 qam 24
I have rebooted the hub and unplugged/reconnected the cable to no avail.
Some of my Speedtests this morning have been as low as 0.39Mbps upload (wired).
Thanks, Glenn
Anonymous
Not applicable
Message 2 of 16
Re: Poor speed - SNR?
SNR does look a bit 'off'.
Could you post the rest of the 'Downstream', and the 'Upstream' tab data?
Glenn2
  • 52
  • 5
Message 3 of 16
12987500001.235256 qam21
21387500001.233256 qam1
31467500000.533256 qam2
41547500000.533256 qam3
51627500001.534256 qam4
61707500001.734256 qam5
71787500001.735256 qam6
81867500001.934256 qam7
91947500001.735256 qam8
102027500001.735256 qam9
112107500001.535256 qam10
122187500001.435256 qam11
132267500001.235256 qam12
142347500001.235256 qam13
15242750000135256 qam14
162507500001.235256 qam15
172587500000.935256 qam16
182667500000.935256 qam17
192747500000.535256 qam18
202827500000.735256 qam19
21290750000135256 qam20
223067500001.735256 qam22
233147500001.935256 qam23
243227500001.935256 qam24
1Locked353960
2Locked33.9216210
3Locked33.41020640
4Locked33.4453660
5Locked34.419890
6Locked34.98450
7Locked354840
8Locked34.96790
9Locked353030
10Locked353910
11Locked354860
12Locked353480
13Locked354530
14Locked353280
15Locked355520
16Locked353390
17Locked354860
18Locked353080
19Locked355650
20Locked353270
21Locked35.51990
22Locked35.51810
23Locked35.5960
24Locked35.71970
15369997935.5512064 qam1
23260004335.5512064 qam4
33939995737512064 qam3
44620001237512064 qam2
3ATDMA0000
4ATDMA0010
Anonymous
Not applicable
Message 4 of 16
Yep, something not right:
1Locked353960
2Locked33.9216210
3Locked33.41020640
4Locked33.4453660
5Locked34.419890
6Locked34.98450
7Locked354840
8Locked34.96790
9Locked353030
10Locked353910
11Locked354860
12Locked353480
13Locked354530
14Locked353280
15Locked355520
16Locked353390
17Locked354860
18Locked353080
19Locked355650
20Locked353270
21Locked35.51990
22Locked35.51810
23Locked35.5960
24Locked35.71970
Lee_R
  • 2.94K
  • 151
  • 279
Message 5 of 16
Hi Glenn2, thanks for posting.
I am really sorry you're having issues with your broadband speeds.  And I'm sorry for the delay in our response.  I would like to take a closer look at your issue on your behalf.  To enable me to do so, I am going to send you a private message.  Please look out for the purple envelope in the top right of your screen.
Lee_R
Glenn2
  • 52
  • 5
Message 6 of 16
Just to update, I don't think the low SNR is my problem because it's low day and night yet my internet speed is terrible during the day mainly.  As I type, at 10pm, I get 100+Mbps.
I suspect it is just over-subscribed in my area these days.  I am fortunate in that I am just out of contract because it is making working from home really difficult and I may have to leave VM.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 16
Glenn2
  • 52
  • 5
Message 8 of 16
My BQM
Glenn2
  • 52
  • 5
Message 9 of 16
My BQM has been running a couple of days now but I don't know if it's good or bad.
My internet experience has not been too bad in this period though so might not be representative
Nigel1971
  • 115
  • 6
  • 5
Up to speed
Message 10 of 16
That BQM graph is horrendous, very high latency and spikes shown in yellow, should be pretty much flatter above the green area.
——————————————— My Broadband Ping - Virgin 500mb Home Connection
