09-08-2021 15:02 - edited 09-08-2021 15:03
Noticed over the last couple of days that I am getting poor connection and download speeds. I am currently on the M500 package but after running speed tests I am only getting on average around 88Mbps, which is obviously a problem. It doesn't matter what time of day I run the speed test because the result is the same. I have already rebooted the Hub 3 and that did not fix it.
Anyone any idea what is causing this or do I need to contact Virgin.
Many thanks.
on 09-08-2021 15:59
on 09-08-2021 16:10
I have just looked in device manager under network settings and according to the screenshot there is no ethernet connection. Is this correct? It seems very odd that it's not showing.
on 09-08-2021 16:46
I have found the ethernet adapter in windows but it is only showing as 100Mbps.
09-08-2021 17:01 - edited 09-08-2021 17:04
Thats your issue then 🙂
Have you tried a new cable - if that is borked it could drop connection down to 100
I cant help any further as I have never used Windoze - Macs only 🙂
But are you using an ethernet adapter and not an inbuilt wifi card? If so, is it actually specced as a 1GB connector - or just 10/100? Cheap enough to swap to a new GB one though.
If inbuilt... check drivers are up to date or someone else will suggest something
on 09-08-2021 17:26
It is a Gigabit card and all drivers are up to date. Only last week everything was working perfectly and I only noticed it because I was getting slow download speeds on Steam whereas before they used to fly.
