Northerneruk
Message 1 of 5
Poor Speed, constantly bufferingz
Anyone else suffering poor speeds in the Lancaster/Morecambe area. YouTube has been buffering regularly now for the last 2 weeks. Never had it this bad with previous supplier who only offered 19Mbps. Chose Virgin for 100Mbps but disappointed.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 5
Re: Poor Speed, constantly bufferingz
Which Hub do you have ?
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Northerneruk
Message 3 of 5
It’s a Hub 3, not the best but it was fine until about 2 weeks ago. Reset, turned it off but nothing has worked.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 5
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Disable any VPNs that you have running.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 5
Can you please
