on 24-04-2022 11:19
Hi, we recently upgraded to M200 from M100.
The package has been applied because when I do a speed test, our upload speed is now 20Mbps whereas before it was only 10Mbps.
However the download speed has remained at between 60 and 80Mbps, this is even lower than the 90Mbs we used to average on the M100 service.
So, does it take time for the speed to settle or does our equipment need changing? We have a Superhub2. All testing has been completed on CAT5 wired machines running Windows 10, WiFi is disabled in the router as we do not use it.
Any ideas, or should I just request we go back to M100?
on 02-05-2022 14:42
Good Afternoon @IanSR, I'll be able to look into a hub replacement for you, check out the purple envelope in the top right hand corner from me
Kindest regards,
David_Bn
on 04-05-2022 09:18
Hi Ian, Thank you for coming back to us! Sorry to hear you are experiencing issues with latency and packet loss.
Having had a look on our systems there are no issues showing with the signals coming into your hub from the exchange.
There are some settings with the Wi-Fi bands on your hub which are showing as out of specification at the moment which may be causing you issues. (Both the 2.4ghz and 5ghz Wi-Fi band are currently disabled.)
Is this something you are aware of? If you would be able to do a pinhole reset on your hub this will return it to factory settings, refresh all connections and hopefully resolve some of the issues.
If you can please let us know how you are getting on following the pinhole reset so we can offer further support and diagnostics.
All the best!
on 04-05-2022 10:29
@Molly_T wrote:Hi Ian, Thank you for coming back to us! Sorry to hear you are experiencing issues with latency and packet loss.
All the best!
With all due respect, I disagree that there is not an issue, and the issue is quiet well known, you literally have a forum full of angry customers so it's not isolated, I like that you say there is no issue between my hub and the exchange, well yes that's because the issue that is quiet well established now is at a network level (i.e. beyond my local exchange).
I have tried several factory resets and nothing fixes it, the issue is not my hub, it's not the local exchange, it's deep withi n the network core and only Virgin Media network engineers themselves can fix this.
Thanks.
on 06-05-2022 14:05
Hi @IanSR
Are you able to share your live BQM so that we can see where/when you are experiencing these packet loss and latency issues. I have check the systems both at the exchange and in the area and I cannot see anything that might be causing these issues on your service.
on 08-05-2022 08:46
Here you go:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/767cc38a43d183b202017fcc898fba7dbc...
I suspect the humps Saturday were me uploading stuff to Youtube while also streaming other stuff, I can imagine if you push the system to it's limit you can induce what looks like network utilisation issues, so for now just ignore them, the main issue is the weekday (Monday to Thursday) latency and lost packets that happen between 7.30pm ish and 10.30pm, that makes gameplay impossible during these times.
It's also been suggested that I post these details for you:
Downstream DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) | 138750000 | 146750000 | 154750000 | 162750000 | 170750000 | 178750000 | 186750000 | 194750000 |
Lock Status(QAM Lock/FEC Sync/MPEG Lock) | Locked | Locked | Locked | Locked | Locked | Locked | Locked | Locked |
Channel ID | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 |
Modulation | 256QAM | 256QAM | 256QAM | 256QAM | 256QAM | 256QAM | 256QAM | 256QAM |
Symbol Rate (Msym/sec) | 6.952000 | 6.952000 | 6.952000 | 6.952000 | 6.952000 | 6.952000 | 6.952000 | 6.952000 |
Interleave Depth | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 |
Power Level (dBmV) | 3.97 | 3.93 | 4.11 | 4.05 | 3.83 | 3.60 | 3.41 | 3.39 |
RxMER (dB) | 36.84 | 37.09 | 37.09 | 36.84 | 37.36 | 37.64 | 37.09 | 37.09 |
Pre RS Errors |
69825 | 38290 | 7371 | 9729 | 2025 | 1569 | 1748 | 1338 |
Post RS Errors |
288 | 304 | 287 | 285 | 303 | 291 | 277 | 301 |
Upstream US-1 US-2 US-3 US-4
Channel Type | 2.0 | 2.0 | 2.0 | 2.0 |
Channel ID | 7 | 6 | 5 | 8 |
Frequency (Hz) | 46200000 | 53700000 | 60300000 | 39400000 |
Ranging Status | Success | Success | Success | Success |
Modulation | 64QAM | 64QAM | 64QAM | 64QAM |
Symbol Rate (Sym/sec) | 5120000 | 5120000 | 5120000 | 5120000 |
Mini-Slot Size | 2 | 2 | 2 | 2 |
Power Level (dBmV) | 41.50 | 41.50 | 41.75 | 41.50 |
T1 Timeouts | 0 | 0 | 0 | 0 |
T2 Timeouts | 0 | 0 | 0 | 0 |
T3 Timeouts | 0 | 0 | 0 | 0 |
T4 Timeouts | 0 | 0 | 0 | 0 |
First Time | Last Time | Priority | Error Number | Description |
07/05/2022 20:43:25 GMT | 07/05/2022 20:43:25 GMT | Error (4) | 68010300 | DHCP RENEW WARNING - Field invalid in response v4 option |
04/05/2022 08:43:18 GMT | 04/05/2022 08:43:18 GMT | Error (4) | 68010300 | DHCP RENEW WARNING - Field invalid in response v4 option |
01/05/2022 08:09:50 GMT | 01/05/2022 08:09:50 GMT | Error (4) | 68010300 | DHCP RENEW WARNING - Field invalid in response v4 option |
29/04/2022 09:11:04 GMT | 29/04/2022 09:11:04 GMT | Warning (5) | 66050310 | Auth Success - Web login successful. |
28/04/2022 20:03:49 GMT | 28/04/2022 20:03:49 GMT | Error (4) | 68010302 | DHCP WAN IP - xx.xxx.xx.xx |
28/04/2022 20:02:57 GMT | 28/04/2022 20:02:57 GMT | Error (4) | 68000407 | TOD established |
Time Not Established | Time Not Established | Notice (6) | 84000510 | Downstream Locked Successfully |
28/04/2022 20:00:21 GMT | 28/04/2022 20:00:21 GMT | Error (4) | 68010302 | DHCP WAN IP - xx.xxx.xx.xx |
28/04/2022 19:59:27 GMT | 28/04/2022 19:59:27 GMT | Error (4) | 68000407 | TOD established |
Time Not Established | Time Not Established | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
28/04/2022 09:17:03 GMT | 28/04/2022 09:17:03 GMT | Warning (5) | 66050310 | Auth Success - Web login successful. |
28/04/2022 08:59:39 GMT | 28/04/2022 08:59:39 GMT | Error (4) | 68010302 | DHCP WAN IP - xx.xxx.xx.xx |
28/04/2022 08:58:45 GMT | 28/04/2022 08:58:45 GMT | Error (4) | 68000407 | TOD established |
28/04/2022 08:46:30 GMT | 28/04/2022 08:46:30 GMT | Error (4) | 68010302 | DHCP WAN IP - xx.xxx.xx.xx |
28/04/2022 08:45:40 GMT | 28/04/2022 08:45:40 GMT | Error (4) | 68000407 | TOD established |
28/04/2022 08:36:36 GMT | 28/04/2022 08:36:36 GMT | Warning (5) | 66050310 | Auth Success - Web login successful. |
Have removed IP address and replaced with xx.xxx.xx.xx.
on 10-05-2022 11:16
Hello @IanSR,
Thanks for sharing this information.
Can you please tell me if you have checked your advanced settings? Our system is showing that your 5GHz is disabled which can cause interference and congestion issues.
Many thanks,
on 10-05-2022 12:08
The problem appears to have been fixed somewhere else in the network now, but are you seriously trying to say turning off 5G Wifi causes congestion? HOW?
5G Wifi was switched off the day the router was delivered probably 5+ years ago, and 2.4Ghz Wifi was disabled 2 years ago, the problems that everybody has been experiencing started a month ago.
How did turning 5G wifi off 6 years ago cause the congestion during April and May 2022?
