bombkangaroo
  • 8
Message 1 of 13
Packet loss issue
I've been getting intermittently low speeds recently. My BQM graph is showing a lot of periods of very high packet loss, and I'm noticing a lot of buffering and quality reduction in streaming video, and also rubber banding in multiplayer games when it happens.
I've checked my connections and everything seems to be plugged in securely.
Ethernet:
https://www.speedtest.net/result/12499918577
1298750000-3.240256 qam21
2234750000-5.737256 qam13
3242750000-637256 qam14
4250750000-4.738256 qam15
5258750000-438256 qam16
6266750000-3.938256 qam17
7274750000-3.538256 qam18
8282750000-3.740256 qam19
9290750000-3.240256 qam20
10306750000-2.738256 qam22
11314750000-3.240256 qam23
12322750000-2.540256 qam24
13330750000-340256 qam25
14338750000-2.740256 qam26
15346750000-3.240256 qam27
16354750000-3.240256 qam28
17362750000-3.540256 qam29
18370750000-3.440256 qam30
19378750000-440256 qam31
20386750000-4.540256 qam32
1Locked40.3153725
2Locked37.334358270
3Locked37.3374271
4Locked38.621270457
5Locked38.92140249
6Locked38.9173338
7Locked38.6132337
8Locked40.3119127
9Locked40.3130120
10Locked38.994520
11Locked40.9102411
12Locked40.39068
13Locked40.38679
14Locked40.38716
15Locked40.35445
16Locked40.36671
17Locked40.97376
18Locked40.96285
19Locked40.97866
20Locked40.35089
14620000051512064 qam2
23940000049.3512064 qam3
35370000051512064 qam1
43260000050.8512064 qam4
3ATDMA0000
4ATDMA0000
Tags (2)
carl_pearce
  • 1.41K
  • 91
  • 309
Knows their stuff
Message 2 of 13
Re: Packet loss issue
Uncorrected errors on downstream channels and too high power level on upstream channels shows you have an issue.
Downstream power levels look a touch low, even though in spec.
bombkangaroo
  • 8
Message 4 of 13
Thanks for the quick response.
21/12/2021 21:18:28Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2021 21:18:27Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2021 21:09:13Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2021 21:09:12Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2021 21:08:55Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2021 21:08:54Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2021 21:02:18Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2021 21:02:18Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2021 21:02:6Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2021 21:02:6Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2021 21:02:0Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2021 21:02:0Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2021 21:01:42Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2021 21:01:42Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2021 21:01:29Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2021 21:01:28Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2021 21:01:6Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2021 21:01:6Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2021 21:00:54Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2021 21:00:54Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
carl_pearce
  • 1.41K
  • 91
  • 309
Knows their stuff
Message 5 of 13
Terrible connection.
VM need to look into this.
Hayley_S
  • 3.9K
  • 129
  • 255
Message 6 of 13
Hello @bombkangaroo,
Welcome to the community, thanks for posting.
I am sorry about the issues with your connection.
Is this with your wired and wireless? Or just wireless? Have you tried doing a pinhole reset?
Many thanks,
Hayley
bombkangaroo
  • 8
Message 7 of 13
Hi @Hayley_S,
This is both wired and wireless, and I can confirm that I have tried a pinhole reset. Resetting the router typically improves things for a short period of time, but the connection soon deteriorates again.
Hayley_S
  • 3.9K
  • 129
  • 255
Message 8 of 13
Thank you for the update @bombkangaroo.
I am sorry that it is not fixing the issue.
Are you using any 3rd party routers?
Many thanks,
Hayley
bombkangaroo
  • 8
Message 9 of 13
I can confirm that I am not using any third party routers, just the VM Super Hub 3. (plus the VM phone gubbins for the landline if that's any help)
I just tired another pinhole reset this morning, and my speedtest results improved immediately afterwards:
https://www.speedtest.net/result/12521624201
But then ten minutes later we're back to this:
https://www.speedtest.net/result/12521653580
The router status still shows Partial Service (DS).
carl_pearce
  • 1.41K
  • 91
  • 309
Knows their stuff
Message 10 of 13
Many thanks,
There is clearly an issue with their line.
Look at the BQM!
