Daniel_C
  • 100
Message 31 of 50
Re: Packet loss and low upload
Daniel_C
  • 100
Message 32 of 50
Daniel_C
  • 100
Message 33 of 50
  • 18.62K
  • 773
  • 1.96K
Message 34 of 50
@Daniel_C wrote:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/create/05d39cc65ced610503f60cd9fe1...
yes you seem to have a bit of packet loss likely on the upstream way to test would be to Wireshark the WAN in modem mode to see if your getting all requests.
you can do a short ping test to ping -n 200 194.168.4.100
Daniel_C
  • 100
Message 35 of 50
Where do I do the ping test?
To Wireshark the WAN I would need to login into my hub settings right? Sorry this is all new to me and I don't fully understand how to do it all.
  • 18.62K
  • 773
  • 1.96K
Message 36 of 50
Wireshark is a bit more of testing to find if packet drop upstream or downstream using BQM as a guide.
you can log in to your hub and find the t# timeouts counter which may show something.
run CMD in windows then
Daniel_C
  • 100
Message 37 of 50
Ok, did the ping test,  these are the figures
Pinging 194.168.4.100 with 32 bytes of data:
Reply from 194.168.4.100: bytes=32 time=13ms TTL=61
Reply from 194.168.4.100: bytes=32 time=16ms TTL=61
Request timed out.
Reply from 194.168.4.100: bytes=32 time=10ms TTL=61
Reply from 194.168.4.100: bytes=32 time=12ms TTL=61
Reply from 194.168.4.100: bytes=32 time=15ms TTL=61
Reply from 194.168.4.100: bytes=32 time=7ms TTL=61
Reply from 194.168.4.100: bytes=32 time=8ms TTL=61
Request timed out.
Reply from 194.168.4.100: bytes=32 time=6ms TTL=61
Reply from 194.168.4.100: bytes=32 time=9ms TTL=61
Reply from 194.168.4.100: bytes=32 time=14ms TTL=61
Alex_RM
  • 6.31K
  • 328
  • 463
Message 38 of 50
Hi Daniel_C,
Sorry to see you're still experiencing an issue with the connection.
I have had a look at things from our side and can see there is an area SNR issue ongoing, this is currently set to be fixed on the 19th April.
Please let us know how you get on after this date.
Alex_Rm
Daniel_C
  • 100
Message 39 of 50
Hi Alex, still suffering some packet loss after the fix date has passed.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/41231e6e251120221d7c782baeeae99f0b169893
Beth_G
  • 4.8K
  • 276
  • 511
Message 40 of 50
Hi Daniel_C,
I'm sorry to hear that you're still having issues with your connection.
I have checked the fault reference and can see that the estimated fix date for this issue has been delayed to the 26th April. I am really sorry about that.
I can appreciate this must be frustrating but please be assured that we'll be working hard to resolve this.
Kind regards
Beth
