grindles
Packet loss and latency
I've been experiencing quite bad packet loss and latency spikes affecting video calls, online gaming severely. It seems to be worse with cold/damp weather, and seemed to start after I had my cable repaired (a patch was applied inside a plastic box, it's sitting on top of damp soil).
I don't know whether this is my connection to VM (my home network is fully wired) or something in VM's infrastructure e.g. locally. I've just started a thinkbroadband.com BQM, and I'll see if that reveals any kind of trend, but in running ping to various internet endpoints I saw significant packet loss and spikes in latency. I've also now moved the patch off the damp earth to see if that helps.
Here are the statuses from the VM hub.
12030000006.540256 qam9
22110000006.540256 qam10
32190000006.540256 qam11
42270000006.540256 qam12
52350000006.640256 qam13
62430000006.940256 qam14
72510000006.940256 qam15
82590000006.940256 qam16
9267000000740256 qam17
10275000000740256 qam18
11283000000740256 qam19
12291000000740256 qam20
132990000007.540256 qam21
143070000007.640256 qam22
153150000007.640256 qam23
163230000007.440256 qam24
17331000000740256 qam25
183390000007.140256 qam26
193470000007.440256 qam27
203550000007.140256 qam28
213630000007.440256 qam29
223710000007.540256 qam30
233790000007.540256 qam31
24387000000740256 qam32
1Locked40.34500
2Locked40.31480
3Locked40.32520
4Locked40.95330
5Locked40.32660
6Locked40.92200
7Locked40.97240
8Locked40.94790
9Locked40.91620
10Locked40.92170
11Locked40.92730
12Locked40.32050
13Locked40.92990
14Locked40.91600
15Locked40.95600
16Locked40.32910
17Locked40.92130
18Locked40.93560
19Locked40.93890
20Locked40.31720
21Locked40.92540
22Locked40.95380
23Locked40.92490
24Locked40.3990
grindles
Re: Packet loss and latency
The rest of the status that didn't fit:
15370000042.5512064 qam2
26030000043.3512064 qam1
33939994643.3512064 qam4
44620000042.8512064 qam3
1ATDMA0050
2ATDMA0030
3ATDMA0030
4ATDMA0010
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt062+voc-b.cm
SFID65518
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID65517
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
26/11/2020 17:57:34noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2020 13:45:1ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2020 00:06:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/11/2020 01:45:0ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
grindles
I'm quite disturbed by the silence in response to this, especially as VM don't appear to have any way to get in touch with customer services.
I've been tracking this as an ongoing issue, it hasn't gone away. Here's an example from today, which is not special.
BQM
