  • 30
  • 8
all129
Message 1 of 14
Packet Loss
Summary
Packet loss started a.m. Friday 21 December; continued; increased markedly today (23 December) to c. 20 per cent.
Steps tried
Checked all hardware connections.
Rebooted modem.
Speed checks out OK.
VM online checks show no issues.
Details
BQM graphs are at
https://www.thinkbroadband.com/broadband/monitoring/quality/share/735204851da58cb68730526255afb7cdba...
 https://www.thinkbroadband.com/broadband/monitoring/quality/share/4ddf529de525478f99ea6d7ad963f403cc...
https://www.thinkbroadband.com/broadband/monitoring/quality/share/b3809eb0bbf4b69f7ca84027a7974d4332...
Power levels etc etc
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
299000000
6.5
38
256 qam
21
2
403000000
6.6
40
256 qam
28
3
395000000
6.6
40
256 qam
27
4
387000000
6.5
40
256 qam
26
5
379000000
6.5
40
256 qam
25
6
323000000
6.4
38
256 qam
24
7
315000000
6.3
40
256 qam
23
8
307000000
6.4
40
256 qam
22
9
291000000
6.3
38
256 qam
20
10
283000000
6.1
40
256 qam
19
11
275000000
5.9
38
256 qam
18
12
267000000
6
40
256 qam
17
13
259000000
5.9
40
256 qam
16
14
251000000
6
38
256 qam
15
15
243000000
6
38
256 qam
14
16
235000000
6.1
38
256 qam
13
17
227000000
6.3
38
256 qam
12
18
219000000
6.3
40
256 qam
11
19
211000000
6.4
38
256 qam
10
20
203000000
6.4
38
256 qam
9
21
195000000
6.5
40
256 qam
8
22
187000000
6.5
38
256 qam
7
23
179000000
6.8
40
256 qam
6
24
171000000
7
40
256 qam
5
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.9
162
0
2
Locked
40.3
85
0
3
Locked
40.3
217
0
4
Locked
40.3
232
0
5
Locked
40.3
291
0
6
Locked
38.9
159
0
7
Locked
40.3
223
0
8
Locked
40.9
108
0
9
Locked
38.9
357
0
10
Locked
40.3
292
0
11
Locked
38.9
331
0
12
Locked
40.3
237
0
13
Locked
40.3
268
0
14
Locked
38.9
265
0
15
Locked
38.9
236
0
16
Locked
38.9
246
15
17
Locked
38.9
227
25
18
Locked
40.3
271
33
19
Locked
38.9
223
14
20
Locked
38.9
246
5
21
Locked
40.3
301
2
22
Locked
38.9
308
1
23
Locked
40.3
244
7
24
Locked
40.3
255
6
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
53700000
44
5120
64 qam
6
2
60300000
44.5
5120
64 qam
5
3
46200000
43.8
5120
64 qam
7
4
39400000
43.5
5120
64 qam
8
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
6
0
2
ATDMA
0
0
11
0
3
ATDMA
0
0
2
0
4
ATDMA
0
0
3
0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-rtsl10016u-b.cm
SFID
2930
Max Traffic Rate
115000000
Max Traffic Burst
10000
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
2929
Max Traffic Rate
6320000
Max Traffic Burst
16320
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
BestEffort
  • 12.55K
  • 481
  • 1.12K
Message 2 of 14
Re: Packet Loss
Thats a bad connection you got their likely upstream noise yet your modulation stays at 64qam and does not drop to 16qam.
  • 30
  • 8
all129
Message 3 of 14
Re: Packet Loss
I finally managed to speak to VM support who saw nothing wrong from their checks.
  • 10
warbit
Message 4 of 14
Re: Packet Loss
I am getting this same packet loss that started on the same date. Area Code 15, which area are you?
  • 90
  • 6
ozgurcan
Dialled in
Message 5 of 14
Re: Packet Loss
Im having the same issue, area 15 too .Got an engineer coming on friday
  • 30
  • 8
all129
Message 6 of 14
Re: Packet Loss
I am also Area 15.  I think I'll phone again as the packet loss is still there and peaking at around 20%.
  • 23
  • 8
Sptz
Message 7 of 14
Re: Packet Loss
My Broadband Ping - Virgin Media SH3Same here... Again with this crap in this area. Also Area 15... We had that horrendous time 2 weeks ago now it seems to be making a comeback.
  • 30
  • 8
all129
Message 8 of 14
Re: Packet Loss
Continuing loss this a.m.  Spoke VM support.  Visit booked for 2 January.
FWIW I notice your (Sptz's) graph shows packet loss coincides with vastly increased latency just like mine don't.  I've no idea of the odds but I'd guess that with such a large base of users in Area 15 we might all have coincidental but separate, local faults.   Shame as it'd be nice to imagine a devoted VM engineer trudging through the snow to fix core network hardware and so give many people what they want most on Christmas day - the ability to ignore get online and ignore who they're with Smiley Sad
  • 30
  • 8
all129
Message 9 of 14
Re: Packet Loss
An update - which in summary is no change in the service but a markedly less happy customer.
Tech. arrived on 2 January (late, without apology or explanation).  Not interested in my evidence of the problem.  Attached his meter; said there was noise; replaced the F plug at modem and 2 F plugs where cable enters house and fitted an isolator.
When I queried how connections not touched for years could cause a sudden and dramatic onset of dropped packets – and one that then temporarily vanished for a few hours on 29 December –  he suggested I run whatever further tests I wanted.
I did so. The problem remained  as evidenced by BQM; by speeds which vary randomly when downloading large files from news.virginmedia.com; and by manual pings.
Phoned CS on 3 January.  Spent much time going round in circles with someone who seemed not to understand "packets" and insisted on asking if I had "lost the connection" (and yes, I had made clear I was using Ethernet, not wireless, and that there was no problem between PC and router).  I suspected a script where resistance was futile so remained polite and after several periods on hold spoke to her supervisor.
The supervisor told me my router showed 2 devices not properly connected and recognized; that I should disconnect those and monitor further; and assured me that he would call me on Friday or Saturday to check the results.  I said the 2 devices were a Smart TV and a switch which were powered down (and in passing which did not show as connected when I checked the router).  But I agreed to do so, and also volunteered to try putting the router in modem-only mode.
I have done all that (including modem mode).  Nothing changed.  Packet loss continued.
And on top of that there was no call back Friday or today (Saturday).
I’ve had cable internet since it was first made available in Hackney (the old Cable London area).  I’ve sung the praises of the service’s reliability – despite the price.   But the lack of response since 21 December means I can no longer do so; shall be looking for a formal response; and at other ISPs.
  • 30
holtend4life
Message 10 of 14
Re: Packet Loss
Exactly the same experience in Hackney too.
Im going to have to leave and move to Sky or BT fiber instead, in fact sky will pay the cancellation costs in credit on their bills up to £100 for internet and £250 for internet and tv.
And it’s not just the packet loss issue that has forced me into this decision, it’s the lack of customer service I’ve received their end throughout that makes me think how can I trust them in the future?
I can’t, so why should I give them anymore money.
