on 16-10-2021 13:16
Hi all, had my virgin media installation last satuday (9th Oct) and since then I've had quite a few issues. First day of install the connection dropped a few times, came back after a few minutes each time but was still worrying considering it had just been installed. I haven't experienced this since but then last night I have been getting packet loss issues. Looking into the router status I can see a lot of errors so I've come here to get some insight. My main PC is connected via ethernet to the router, all cables etc are tight.
I set up a BQM as of last night and you can see some packet loss:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/c67ba2a8eeaba4671597ae0f6ebaeb89c9...
Then the live BQM here:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/0e8519d0356254e361c499aac2465c0fe81a53a6
Router Logs:
1 | 387000000 | 1 | 38 | 256 qam | 32 |
2 | 203000000 | 2.4 | 38 | 256 qam | 9 |
3 | 211000000 | 2 | 38 | 256 qam | 10 |
4 | 219000000 | 1.9 | 38 | 256 qam | 11 |
5 | 227000000 | 1.7 | 38 | 256 qam | 12 |
6 | 235000000 | 1.7 | 40 | 256 qam | 13 |
7 | 243000000 | 2.2 | 38 | 256 qam | 14 |
8 | 251000000 | 2.7 | 40 | 256 qam | 15 |
9 | 259000000 | 2.5 | 38 | 256 qam | 16 |
10 | 267000000 | 2.5 | 40 | 256 qam | 17 |
11 | 275000000 | 2.2 | 40 | 256 qam | 18 |
12 | 283000000 | 2.2 | 40 | 256 qam | 19 |
13 | 291000000 | 2 | 38 | 256 qam | 20 |
14 | 299000000 | 2 | 38 | 256 qam | 21 |
15 | 307000000 | 2 | 38 | 256 qam | 22 |
16 | 315000000 | 2.2 | 40 | 256 qam | 23 |
17 | 323000000 | 2.2 | 38 | 256 qam | 24 |
18 | 331000000 | 2.2 | 38 | 256 qam | 25 |
19 | 339000000 | 2.2 | 38 | 256 qam | 26 |
20 | 347000000 | 1.9 | 40 | 256 qam | 27 |
21 | 355000000 | 1.7 | 38 | 256 qam | 28 |
22 | 363000000 | 1.4 | 38 | 256 qam | 29 |
23 | 371000000 | 1 | 40 | 256 qam | 30 |
24 | 379000000 | 1 | 38 | 256 qam | 31 |
1 | Locked | 38.9 | 7973 | 2316 |
2 | Locked | 38.9 | 10158 | 12116 |
3 | Locked | 38.9 | 10329 | 11956 |
4 | Locked | 38.9 | 10114 | 11031 |
5 | Locked | 38.9 | 10138 | 10423 |
6 | Locked | 40.3 | 10146 | 9964 |
7 | Locked | 38.9 | 10028 | 9386 |
8 | Locked | 40.3 | 9978 | 8702 |
9 | Locked | 38.9 | 9954 | 8403 |
10 | Locked | 40.3 | 10013 | 7441 |
11 | Locked | 40.3 | 9905 | 7144 |
12 | Locked | 40.3 | 9956 | 6387 |
13 | Locked | 38.9 | 9904 | 6137 |
14 | Locked | 38.9 | 9594 | 5711 |
15 | Locked | 38.9 | 9734 | 5317 |
16 | Locked | 40.3 | 9409 | 5054 |
17 | Locked | 38.9 | 9294 | 4576 |
18 | Locked | 38.9 | 9293 | 4256 |
19 | Locked | 38.9 | 9146 | 3925 |
20 | Locked | 40.3 | 8989 | 3394 |
21 | Locked | 38.9 | 8664 | 3564 |
22 | Locked | 38.9 | 8621 | 3054 |
23 | Locked | 40.3 | 8310 | 3021 |
24 | Locked | 38.9 | 8074 | 3043 |
on 16-10-2021 13:17
1 | 39400000 | 42.5 | 5120 | 64 qam | 2 |
2 | 25800000 | 41 | 5120 | 64 qam | 4 |
3 | 32600000 | 41.5 | 5120 | 64 qam | 3 |
4 | 46200000 | 42.5 | 5120 | 64 qam | 1 |
1 | ATDMA | 0 | 0 | 2 | 0 |
2 | ATDMA | 0 | 0 | 3 | 0 |
3 | ATDMA | 0 | 0 | 7 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
on 16-10-2021 13:18
15/10/2021 15:23:2 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/10/2021 03:28:47 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/10/2021 10:42:46 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/10/2021 08:28:24 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/10/2021 08:28:24 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/10/2021 08:28:22 | Error | DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/10/2021 16:43:29 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/10/2021 10:11:4 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/10/2021 20:52:13 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/10/2021 14:00:24 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/10/2021 12:32:14 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/10/2021 12:32:14 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/10/2021 11:10:13 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/10/2021 11:10:13 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/10/2021 10:51:58 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/10/2021 10:51:43 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/10/2021 10:51:42 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/10/2021 10:51:42 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/10/2021 10:51:41 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/10/2021 10:51:41 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 16-10-2021 13:32
on 16-10-2021 14:04
Thanks for the reply, I will try what you said and report back with what shows up. I got around to running a test on the website and got this
Though the site still shows "no known issues" listed on the service status. Is this indicitive of an issue with the area, or something internal? As mentioned before we only got the installation done 7 days ago so nothing has been fiddled with, all cables feel very tight and nothing has been tampered with.
on 16-10-2021 14:21
on 16-10-2021 15:39
Called the number and it said there was a fault in the area and that they're working to fix it. It texted me a link to track the issue, however the page the link sent me to shows "we can't see any issues". Not sure what to think, however they have detected an issue in the area at some point.
on 18-10-2021 16:00
Hi @stiffers
Welcome to our Community Help Forum 🙂
Sorry to see you are experiencing issues with your connection, I understand this must be frustrating for you. I would like to take a look into this further for you and see what information I can provide on the fault.
I shall send you a private message now to obtain the details required. Please look out for the purple envelope in the top right corner and get back to me when you can.
Best wishes,
Serena
on 18-10-2021 17:04
I have replied thank you
on 18-10-2021 17:11
Hi @stiffers
Thank you for responding to my private message. I have taken a look and can see that an SNR outage has been detected that is affecting your services.
We have identified the issue and an engineer is working to get it resolved asap.
The currently estimated fix time is 9am on 25/10/2021. Apologies for the disruption to your connection.
Kind regards,
Serena
