on 13-05-2020 23:49
I'm a new customer (have had Virgin Media broadband in the past) and I'm suffering from some odd instability when downloading torrents and in general. Not sure if the problems are related.
Firstly when I'm downloading a torrent the whole connection will throttle to the point where it's not usable, not just the torrent download but the whole internet connection via both wired and wifi. The torrent will download at a few kbps so it's not using the full 500mbps and therefore causing a bandwidth issue... though pausing the torrent will immediately fix the issue and the connection returns to normal. Seems to be identical to this? https://community.virginmedia.com/t5/Speed/Virgin-Media-throttling-P2P/td-p/4142828
Throughout the day I'm also getting intermittent connection drops. Has been happening since I signed up.
Any help would be appreciated!
My Superhub 3 stats:
1 | 443000000 | 5 | 38 | 256 qam | 37 |
2 | 251000000 | 2.2 | 38 | 256 qam | 15 |
3 | 259000000 | 2.7 | 38 | 256 qam | 16 |
4 | 267000000 | 3 | 38 | 256 qam | 17 |
5 | 275000000 | 3.2 | 38 | 256 qam | 18 |
6 | 283000000 | 3.7 | 38 | 256 qam | 19 |
7 | 291000000 | 4.3 | 38 | 256 qam | 20 |
8 | 299000000 | 5 | 38 | 256 qam | 21 |
9 | 307000000 | 5.6 | 38 | 256 qam | 22 |
10 | 315000000 | 6.1 | 38 | 256 qam | 23 |
11 | 323000000 | 6.5 | 38 | 256 qam | 24 |
12 | 347000000 | 7 | 38 | 256 qam | 25 |
13 | 355000000 | 7.1 | 38 | 256 qam | 26 |
14 | 363000000 | 6.6 | 38 | 256 qam | 27 |
15 | 371000000 | 6.1 | 38 | 256 qam | 28 |
16 | 379000000 | 5.8 | 38 | 256 qam | 29 |
17 | 387000000 | 5.4 | 38 | 256 qam | 30 |
18 | 395000000 | 5.5 | 38 | 256 qam | 31 |
19 | 403000000 | 5.5 | 38 | 256 qam | 32 |
20 | 411000000 | 5.5 | 38 | 256 qam | 33 |
21 | 419000000 | 5.5 | 38 | 256 qam | 34 |
22 | 427000000 | 5.5 | 38 | 256 qam | 35 |
23 | 435000000 | 5.3 | 38 | 256 qam | 36 |
24 | 451000000 | 4.8 | 38 | 256 qam | 38 |
1 | Locked | 38.6 | 197 | 0 |
2 | Locked | 38.6 | 528 | 25 |
3 | Locked | 38.6 | 398 | 0 |
4 | Locked | 38.9 | 369 | 0 |
5 | Locked | 38.9 | 375 | 0 |
6 | Locked | 38.6 | 389 | 0 |
7 | Locked | 38.9 | 242 | 0 |
8 | Locked | 38.6 | 207 | 0 |
9 | Locked | 38.9 | 182 | 0 |
10 | Locked | 38.6 | 168 | 0 |
11 | Locked | 38.9 | 150 | 0 |
12 | Locked | 38.9 | 260 | 0 |
13 | Locked | 38.9 | 223 | 27 |
14 | Locked | 38.9 | 202 | 0 |
15 | Locked | 38.9 | 199 | 0 |
16 | Locked | 38.9 | 227 | 67 |
17 | Locked | 38.9 | 204 | 0 |
18 | Locked | 38.6 | 125 | 0 |
19 | Locked | 38.9 | 149 | 13 |
20 | Locked | 38.9 | 148 | 0 |
21 | Locked | 38.9 | 184 | 14 |
22 | Locked | 38.9 | 220 | 14 |
23 | Locked | 38.9 | 191 | 16 |
24 | Locked | 38.6 | 259 | 0 |
1 | 53700000 | 4.725 | 5120 | 64 qam | 2 |
2 | 39400000 | 4.675 | 5120 | 64 qam | 4 |
3 | 46200000 | 4.725 | 5120 | 64 qam | 3 |
4 | 60300000 | 4.725 | 5120 | 64 qam | 1 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
on 25-12-2020 20:25
@TheSinner wrote:
Is there any update for the issue? It cant be related to a certain area only as this excuse sounds pretty dumb to me. Im from RM16 area and experiencing the same. Under consumer rights and per contract VM IS NOT TO THROTTLE speed of any sorts. Can you please explain whats going on please?
VM don't throttle.
No issues here (I disabled DHT in the client which helped with BQM oddities).
on 04-03-2021 20:59
I from SM5 UK and experiencing exactly the same thing. Notably running a VPN instantly inprove the situation. This is unacceptable. When will thete be an update as to what is happening?
on 08-03-2021 13:09
Hello @yloops,
Welcome to our Community Forums and thank you for posting.
Sorry to hear that you are experiencing these issues. As a provider, we do not throttle speeds.
Can you confirm if the instability is when using a wired or wireless connection?
on 08-03-2021 13:54
@yloops wrote:I from SM5 UK and experiencing exactly the same thing. Notably running a VPN instantly inprove the situation. This is unacceptable. When will thete be an update as to what is happening?
Running P2P/torrent on the hubs when many connections go flying causes problems testing here in modem mode with the SH1 has no problems.
on 30-10-2021 05:26
why is it when typing throttling in the search bar there are a huge number of paying customers experiencing this issue ,myself included wether I use a vpn or not the speeds are erratic and unacceptable I pay for 500mb but lucky to get 1mb then a jump to 50mb for a few seconds then back to sub 1mb for minutes.. Skys speeds are not as good as VM but at least they're consistent , when trying to talk to someone you get put through to an Indian call centre who's agents all have the same script telling you to go around the house disconnecting all connected peripherals wasting our time and pee'ing customers off as the problem cannot be relayed properly and the clever but sneaky & disgusting disconnecting of live chat is beyond a joke now.
on 30-10-2021 10:43
I’m not trying to defend Virgin but torrents are working fine for me and I’m using full 1150Mbps when downloading torrents (2 Ethernet cables connected to my PC).
So clearly they are not throttling the connection and the issue is elsewhere.
on 01-11-2021 11:04
Hello Vinsta,
Sorry to hear of the broadband issues experienced, we appreciate you taking the time to raise this via the forums. We have these tips available to help with broadband issues:
When running a speed test we would always recommend running this via a wired connection This can be completed using an ethernet cable via a PC or laptop and will allow us to see the speeds available at the Hub.
We do have the Connect App https://virg.in/connectapp that will allow you to scan your property to optimise the wireless network and if needed order pod's. Depending on your package these may be free but any package is eligible for these if needed.
Rob
on 03-11-2021 10:42
Hi z10m,
Thanks for coming back to Steve via private message.
I have booked you in for the next available appointment. We cannot confirm the appointment time slot, so to view this please sign in to My Virgin Media here: My VM Just go to My Account > Track your orders. You can also view this in the My VM app.
Please ensure that someone over the age of 18 is at the property for the time the engineer is there.
If the appointment is unsuitable or if anyone living at your property has tested positive for Coronavirus, has been asked to self-isolate or has flu-like symptoms then please reschedule the appointment on the same link.
Lets us know how the appointment goes.
Take care.
