bsbai
  • 9
Over utilisation, would an upgrade to 1Gig help ?
Hello,
I have been having trouble with my VM connection since I moved to a new area, and after a lot of reading on this forum, I came to the conclusion that it's probably due to over utilisation.
I am currently on 200Mb speed (Hub3). Would an upgrade to 1Gig help ? if it's going to be running on the same cable as my current connection, I imagine that I will experience the same latency and packet loss issues ...
sophist
  • 2.7K
  • 433
  • 742
Re: Over utilisation, would an upgrade to 1Gig help ?
@bsbai wrote:
Hello,
If it’s an over utilisation issue, an upgrade is unlikely to help much. Docsis 3.1 does use more channels, so you may see a slight improvement but i wouldn’t bank on it
