ajm123
  • 9
Message 1 of 11
Ofcom Speed Test results being withheld
I have been a customer of VM since 2008 and I was persuaded to upgrade to M200 from M100 on September after which my speed fell to 80mbps. Virginmedia then started a 30 day speed review re: Ofcom guidelines. 5 weeks after, I had heard nothing from VM. After managing to get through to a human, I was told that the results had been sent out via mail as they couldnt email me (dont ask me why they cant use email!). The results never arrived and since then, I have been unable to speak to technical via text or phone. I managed to get through to someone this morning who informs me that the speed test period didnt actually take place - when I challenged this, the line went dead. I cannot describe how angry I am at how dismissive VM are of their customers. I have posted my frustrations and have had responses from both BBC Watchdog and Ofcom. VM ..... PLEASE VALUE YOUR CUSTOMERS!!! and while I am at it, stop using the hastag #stayconnected as its utter nonsense
Tags (1)
Anonymous
Not applicable
Message 2 of 11
Re: Ofcom Speed Test results being withheld
Technically you don't have a loss of service...
Are you testing with a wired or wireless device?
ajm123
  • 9
Message 3 of 11
Its wired. Its a loss of speed, so contractually relevant
Anonymous
Not applicable
Message 4 of 11
Well yes, however I was referring to your hashtag comment...
If you access your HUB (HUB 3?) on http://192.168.0.1 and check the 'Connected devices' section what does your wired device show under the 'Speed Mbps' column?
  • 24.06K
  • 2.54K
  • 4.37K
Message 5 of 11
Can you follow this protocol.
If you think that you have a BB speed problem, then to check the speeds coming in to your Hub properly, and whether they match what you should be getting, you cannot rely on wifi tests, - no BB supplier guarantees those - only speeds "TO" the Hub are guaranteed.
So, can you test speeds directly like this. As you expect >100Mbps then connect a 1GB enabled computer/laptop, with up to date drivers, via a known good and working Cat5e (or better) ethernet cable, directly to the Hub which you have put into “modem mode” (see VM website for “How To”). Test at speedtest.net (not the App!) to your nearest VM server - try on 2 different browsers.
If they are still low – boot the device into safe+networking mode and try again.
There are many posts on here where unknown/flaky software, old network card drivers, corrupted browsers, other connected devices, etc, are limiting speeds on tests.
Report back what that gets.
ajm123
  • 9
Message 6 of 11
its says 100 under the ethernet connection
Anonymous
Not applicable
Message 7 of 11
Which is why you can't get your full speed.
You need to check:
  • If your device has a 1Gbps ethernet card.
  • The ethernet cable you are using is capable of 1Gbps.
Buffer6
  • 11.22K
  • 93
  • 632
Hero
Message 8 of 11
If your device is connected to your Hub at only100Mbps, it could mean that the
NIC (Network Interface Card) in your PC/Laptop is not Gigabit compliant
10/100/1000  or has gone faulty, a 100Mbps connection won't allow speeds
greater than 100Mbps, usually a lot less.
Or do you mean that your configuration file in your Hub is set for 100Mbps?
Anonymous
Not applicable
Message 9 of 11
You need to check:
So are we going to get a conclusion to this thread?
Anonymous
Not applicable
Message 10 of 11
@Anonymous wrote:
You need to check:
Now who's the one withholding information!?!
