(Not so) Smart Support remote fix?
mentasm
Up to speed
This is a bit of a weird one, so I'm wondering if anyone has had a similar issue.
On Sunday the power went out in my home. When it came back on nothing (and I mean nothing - multiple laptops, phones, tablets, Google devices etc) would connect to the Hub 5. After a few resets I finally got one machine (my M3 Pro) to connect so I could get into the admin interface. For some reason the channel optimisation was on, which causes havoc with Nest devices (in my experience). I know it was off beforehand, so I tried to turn it off again. It wasn't having any of it, even disabling one channel at a time. I tried a wired connection with another device or two, but only the Mac would connect. In the end I got annoyed and reset the Hub. That took a while, but at least it fixed it and I was back up and running with my usual gigabit speeds. I then (tediously) reconfigured the Hub to rename the SSIDs, change the WiFi channels (as the optimisation does the opposite of that) and security, and tested again. All good.
About 2AM Monday morning it dropped again. Now this isn't unusual - it randomly drops for anything from a few minutes to a few hours every now and then, and I've sort of come to live with it - and in this case it was back within five minutes or so and I got one with what I was doing.
I woke up for work just before nine and had a text saying that VM had identified issues with my connection and to watch for an email. Said email mentioned that this Smart Support thing had made configuration changes to the Hub. When I checked the logs I could only see the 2AM outage, listed as 'unknown'.
Well since then I don't get anything close to the speeds I used to get. I have been reliably been getting 1Gbps and above at all times of the day and night for as long as I've had the service. Today I was averaging between 500-600Mbps, with troughs of 400 and spikes of 700. It's now 1:30AM and I'm still only getting 800Mbps at a push. My upstream was only hitting around 70Mbps and again I've never had less than 100Mbps before.
Now, either everyone in my area decided to get VM broadband installed at the same time and the contention is shot (and I know that's not true as I'm lucky that comparatively few people near me have VM), or it seems something has happened post Smart Support intervention. The fact this also happens when wired means it's not a WiFi issue (and prior to this I got over 1Gbps on WiFi in most rooms of my house using WiFi 6 kit anyway).
Now I understand that correlation doesn't always equal causation, but this seems far too coincidental (and my long experience with VM and its previous iterations has taught me that there's seldom smoke without fire). Has anyone else got anecdotal experience of this occurring after 'Smart Support' intervention?
I've just tried again at almost 2AM and got a little over 500Mbps. Something isn't right.
Cheers
5 REPLIES 5
Lets see the Hub and connection data - can you do this....
________________________________________________
Check first for any “known network faults in your location - Look in 2 places
1) Try the “check service,”Area status webpage (https://www.virginmedia.com/help/service-status)
2) Then also Try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues and fix estimates, down to street cab/ postcode level.
Report back what they say.
Post up your Hub/network connection details and someone will check to see if there is a problem there.  In your browser’s URL type in 192.168.0.1 if in router mode or 192.168.100.1 if in modem mode. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
mentasm
Up to speed
Sadly the service status rarely (if ever) says there are any issues in my area, even during total outages. This was no different. I've since had a second email to say that everything appears to be in 'tip-top' shape, but I'm still seeing a 200-300Mbps reduction in speed compared to the pre-reset speeds, and that's during off-peak times such as now at 1AM (it's often more during peak hours).
I had a TB monitor years ago when I was going through an extended period of trouble with my connection, but to be honest it's been so long it's probably been deleted. I'll look into setting up another when I have a chance. Just to say though, I not just basing this on WiFi speeds. I'm seeing these results on wired gigabit connections to multiple machines (I'm pretty OCD and generally check my speed most days in one form or another, hence knowing it's been consistent for the past 21 months).
Anyway, here are the up/downstream and network logs:
3.0 Downstream channels
13310000002.842QAM 25625
21470000004.842QAM 2562
31550000004.642QAM 2563
41630000004.542QAM 2564
51710000004.542QAM 2565
61790000004.643QAM 2566
71870000004.843QAM 2567
8195000000543QAM 2568
92030000004.942QAM 2569
102110000004.642QAM 25610
112190000004.639QAM 25611
122270000004.543QAM 25612
132350000004.243QAM 25613
142430000004.143QAM 25614
15251000000443QAM 25615
162590000003.742QAM 25616
172670000003.542QAM 25617
182750000003.542QAM 25618
192830000003.542QAM 25619
202910000003.742QAM 25620
212990000003.742QAM 25621
223070000003.642QAM 25622
233150000003.342QAM 25623
24323000000342QAM 25624
253390000002.942QAM 25626
263470000002.842QAM 25627
273550000002.742QAM 25628
283630000002.542QAM 25629
293710000002.442QAM 25630
303790000002.342QAM 25631
313870000002.142QAM 25632
1Locked42641
2Locked424724
3Locked429584
4Locked426397
5Locked4269156
6Locked43405
7Locked435027
8Locked4374160
9Locked42370
10Locked4267174
11Locked39270596
12Locked43444
13Locked4371123
14Locked4342117
15Locked434696
16Locked425278
17Locked425471
18Locked4210939
19Locked4212739
20Locked4210537
21Locked425121
22Locked424112
23Locked42331
24Locked42510
25Locked42657
26Locked42317
27Locked42480
28Locked42500
29Locked42340
30Locked42370
31Locked421019
3.1 Downstream channels
33944K1840QAM 40961108
33Locked41-1.5299691423020
3.0 Upstream channels
04960000044.85120QAM 641
143100000445120QAM 642
23660000043.85120QAM 643
330100000435120QAM 644
423600000435120QAM 645
0ATDMA0000
3ATDMA0000
4ATDMA0000
3.1 Upstream channels
610.440.22KQAM 256
6OFDMA20874000000180
05-09-2024 20:17:57noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
05-09-2024 20:12:54noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
05-09-2024 15:02:37noticeCM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
05-09-2024 14:59:44noticeCM-STATUS message sent. Event Type Code: 16; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2024 23:55:03noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2024 23:44:57noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2024 23:16:16noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2024 23:11:18errorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2024 23:11:13noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2024 22:08:07noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2024 22:03:04noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2024 22:01:57noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2024 21:56:54noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2024 21:56:11noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2024 21:51:08noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2024 21:50:40noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2024 21:45:37noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2024 21:45:09noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2024 21:40:06noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2024 21:39:04noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2024 21:34:01noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2024 21:33:41noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2024 21:28:38noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2024 21:16:37noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2024 21:11:34noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2024 21:11:03noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2024 20:40:26noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2024 20:40:06noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2024 20:30:03noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2024 17:11:52noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2024 16:08:04noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2024 15:28:42noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-09-2024 01:40:11noticeGUI Login Status - Login Success from LAN interface
03-09-2024 01:24:37noticeGUI Login Status - Login Success from LAN interface
02-09-2024 15:36:30notice
Hi @mentasm
Using a wired connection to your PC/laptop  what readings show using?
I would also check the automated status number as suggested by John 0800 561 0061
https://samknows.com/realspeed/
Dave
Hi, as mentioned, those are wired speeds and there are no reported issues in my area. This happened after resetting the hub and I'm still seeing speeds 2-300Mbps lower than before. It's frustrating.
Thanks for coming back to us mentasm. I have looked into this further and cannot see any issues with your connection or in the local area that would be causing the problems that you're having. How are things looking at the moment for you, have you seen any improvement since you last posted?
Kind Regards,
Steven_L
