  • 7
Jond5150
Message 1 of 9
Not reaching 100mb on vivid 100
Screenshot_20190119-102944.jpgOnly getting these speeds after virgin ungraded my to vivid 100 the last time I had a fault. Engineer said I'd been upgraded for free but I appear to be paying for vivid 100 on my account for speeds I'm not getting. How do I fix this as not getting any help in the contact us section
  • 2.42K
  • 117
  • 313
jpeg1
Problem sorter
Message 2 of 9
Re: Not reaching 100mb on vivid 100
I can't see your picture, but what devices are you using  and how are they connected to the Hub?
  • 7
Jond5150
Message 3 of 9
 Super hub 3 (I've tried picture again)
  • 2.42K
  • 117
  • 313
jpeg1
Problem sorter
Message 4 of 9
You haven't answered my question.
  • 7
Jond5150
Message 5 of 9
Sorry, read message wrong.
Phone, tablet, laptop, tv, PS4. Done test when only my phone connected and nothing else switched on/connected
  • 12.52K
  • 954
  • 2.8K
Message 6 of 9
most of those devices are via wifi and anything is possible they are no measure of the speed you might be getting - is the laptop wired - if not do a wired test - if thats still slow do the test again with hub in modem mode
and post some info
log into hub3 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labeled - upstream - downstream
if its an earlier hub button is top right
____________________
Tony
  • 2.42K
  • 117
  • 313
jpeg1
Problem sorter
Message 7 of 9
As Tony says, you have to connect to the hub directly with an ethernet cable to check the speed that VM is providing you. Your tests with a phone won't be valid.
Having said that, I can now see the speed tests and the speeds you are getting are not really bad for a WiFi connection.
  • 7
Jond5150
Message 8 of 9
Plugged ethernet into laptop and got 89mb. Tried phone and tablet directly after and got 78mb and 98mb respectively.
Jon
  • 2.42K
  • 117
  • 313
jpeg1
Problem sorter
Message 9 of 9
So really there is not a lot wrong.
98Mb WiFi on a 100Mb connection is as good as you will get.
Remember that the bandwidth is shared between all the devices you have connected.
