on 09-11-2021 16:13
As title, getting about 400mbs download and strangely 52mbs upload. Multiple reboots and restarts
Hub not recognised by Sam knows website, so it is most likely to blame.
An engineer called today and left a "You weren't in"(I've been sitting in silence waiting for a knock) I was told he would call me on the phone before he arrived (he didn't).
Now after finally getting through to "customer service" I'm told I have to wait another four days for the nest slot. Even though it was only 15 minutes after he "called" there is apparently no way of getting in touch
on 10-11-2021 02:08
on 10-11-2021 11:02
Check the conf settings on the Hub. It will show what speed has been provisioned. It's Configuration tab - Primary Downstream Service Flow - Max Traffic Rate. What does it say?
Speeds are only guaranteed to the Hub and need to be tested with a known good Cat 6 cable, directly connected to the Hub, using a gigabit capable device.
VM do not guarantee wifi speeds.
on 10-11-2021 19:25
on 10-11-2021 19:33
yes, by wire.
on 13-11-2021 12:35
Hi BillHopkinson,
Thanks for coming back to us, what device are you using to do the test on, does it have a gigabit network card installed?
Paul.
